Question about Refrigerators
Fidge will not stop nunning and is not very cold
My frige is constantly running and not very cold and there is moister in the frige can some one give me a tip on what to do?
    Guru:
  • 462 Answers
Is it an auto defrost?
DOes the freezer have a fan in it?
And can you hear it when you push in any door buttons?
Does it have an electronic display on the door or inside any place?
DO the doors anmd seals close good when the door is closed (take a piece of paper and put it tween the door and the frame and remove it by pulling it out. If there is resistance evenly all around the door the seals are good. Usually there is sweat drops of water or maybe milldew where the door seals do not seal. any magnetic part that has the plasitc broken is unsanitary and should be replaced evewn if it is sealing. NO CRACKS is the best advise. cracked away vynal is bacteria favorite hiding place.
If this helps you decide what cause of action to take please let me know by giving me as high a mark as possible. If you need to knwo more please post and I'll check back to read more information has you post it. Thanks for using fixya.
Posted on May 29, 2009
  • 864 Answers
How old is it?  Coolant level may be low.
Freezing up in duct system frig part
Have you checked the heater/defroster element within the freezer? It may be related. When mine failed I was doing the defrosting with a hair blower. Over time (several days) the frost would build up on the freezer coils and the air couldn't flow as it should....so the thermostat wasn't getting cooled enough and it relayed the information to the cooling system, causing the frige to run all the time. Since it was clogged with frost, the frige was constantly trying to cool itself and the frost problem would get so bad that things in the freezer began to melt due to a lack of cold air circulation. After the heater/defroster element was replaced, frost would melt during the defrost cycle (as it should) and airflow/circulation was restored, allowing the thermostat to be cooled properly. Then the freezer coil was able to 'rest' when it should instead of constantly freezing to meet the demand for cold air in the frige. Hope this makes sense...and helps solve your issue.
Apr 11, 2014 | Kenmore Refrigerators
MY FRIGE STOPPED WORKING
HI.THIS needs elaboration.on a general note i am assuming its running but not getting cold.1-check con/unit and should hotish.lack of refrigerant if it is cold and motor running.2-cond/uni cold and motor v/hot and not runnig.suspect motor.con/unit cold motor cold.suspect thermostat the motor.good luck hope it helps.Ali
Jun 18, 2012 | Haier Refrigerators
Fridge fan motor is making a wining noise constantly when fridge is shut, seems continually cooling
if fan motor making noise its not turning fast enuff to get frige cold enuff to shut off replace it
Dec 27, 2009 | Fisher Refrigerators
Refrigerator isnt cold anymore but is running
Sounds like a too low setting or the compressor shut down.
Dec 01, 2009 | Cars & Trucks
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Runs but does not remove water
If only the bottom part if your coil is geting cold or freezing, it's low on Freon.
Please rate solution
Sep 05, 2009 | Fedders R6DH45X Dehumidifier
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Fidge freezer is not working properly
Get british gas homecare cover for heating and appliances, don't tell 'em the freezer isn't working, then a month later report it as a fault, they'll fix it. Unscrupulous i know but what can ya do? Otherwise get a hotpoint engineer, sign up for their maintenance plan.
Apr 04, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
