Question about Carrier Heating & Cooling
Error code: flashes 5 times. model 38yz012 & 38yz009
Carrier 38YZ012-38YZ009 STARTS AND AFTER 3 MINUTES STOPS and the led flash 5 times. Can you help me please with this problem >
  • 1 more comment
  • am11042 May 29, 2009
    Thank you for your responce, There is a green light flash 5 times in the indoor unit
  • Farley Redfield
    Farley Redfield May 11, 2010
    wow I have only known aboiut the redlights and they usually have a slow then a fast blink code that you read. I E 3 slow 4 fast = 34
    Is this an electric furnace? A heatpump outside perhaps? tell me all details you can as well as type of thermostat and any work that has been performed.
  • Farley Redfield
    Is this a light you see flash 5 times and where is it in the outdoor unit inside the indoor unit on the thermostat?
3 Suggested Answers
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
bobotfel
  • 236 Answers
SOURCE: carrier hi wall split unit on light flashes 4 times ???
This problem is outdoor unit issue. Blinking 4 times in carrier highwall unit means Compressor drive malfunction. Possible cause are the following: - Stuck up or grounded compressor. - Magnetic contractor in outdoor unit is defective or indoor unit relay supplying outdoor unit is defective. - No power supply going to outdoor unit.
Posted on Dec 06, 2011
Sir, carrier model42QG24-C comeing to off after 5 mint and then on after some time it repeate this cycle again and again. The red led on pcb is blinking regulerly..
More than likely it is cycling on its low pressure control.. It is an automatic reset device but each time it cycles off, the TDR (time delay relay) keeps it from restarting for approximately 5 minutes.
A steady and rhythmic 'heartbeat' on the circuit board typically means 'normal' operation. If it flashes, stops, flashes, stops etc, it would be giving you a fault code telling you what is cycling it off. You have to count the flashes, slow or fast or a combination of slow and fast and look up the fault codes.
Apr 28, 2015 | Carrier Heating & Cooling
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
While watching my sony KDL-46NX810 TV its suddenly shut off and starts blinking 3 times red standby light. Please have me inform, what this error means and how to repair or what to replace on my...
Hi Gerard,
3 flashes of the led light on most KDL series is a power supply malfunction. To confirm the error code, lets access the self diagnostic screen by following the steps below.
Unplug the unit from the outlet for 30 minutes and then plug it back in and check if the symptoms remain the same. Wait until the led light stops from flashing and then press in rapid sequence the "Display", "Channel 5", "Volume (-)", "Power" button key on the remote control. Self diagnostic screen will be display. Let me know the result.
Jdvillanueva
Nov 09, 2011 | Sony KDL-46NX810 46 in. 3D LCD TV
I have an 18000BTU unit that has an LED that flashes 5 times and then stops,could you pls advize as to the error code of the LED flashes.
You haven't mentioned the brand name. As the error code changes brand to brand I give some solutions. Check with your unit.
e-5 Outdoor activation of compressor over heat protection-Clean condenser coil and check out door f.motor speed. If less replace capacitor.
e-5. Blower motor lock Rotate manually. If hard to rotate, replace bearings or motor. If easy to rotate, replace capacitor.
Please mention brand name and other full details to get solution quickly. Thanks.
Jan 10, 2011 | Carrier 36KCARMS Air Conditioner
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Kenmore model 417-44052400 front load washer error code E04 (5 vertical LED flashes & beeps and 4 start led flashes. I ran the diagnostic test, it dose everything up to tumble, it won't tumble or...
Take the front lower panel off 2 or 3 screws you will see the pump.You will see a black "baffle" atatched to the pump.squeeze it feel a sock?Take the boot loose and clear.Only other thing would be the motor control board back let hand corner replaced many of these when tubs dont move.I hope this helped.
Nov 17, 2009 | Crock Pots & Slow Cookers
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
Heating & Cooling Logo
418 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
