Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
My Sony TV dont turn on?
How do i fix it
  • Sony Master
  • 19,396 Answers
If the TV does not turn on at all, with no lights and no sign of life watsoever, then you probably have a faulty power supply.
If the led is on, or blinking then TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 30, 2009
Sony tv picture goes green
HAVE IT REPLACE WITH A NEW ONE
Sep 12, 2012 | Sony Internet TV NSZGT1
What does standby mean? my tv will not come on but the red standby light is on. How can i fix my tv.My tv is an sony 40" trinitron wega brand.
If standby red light is solid then press power or channel button on remote of tv itself to turn it ON.
And if red light is blinking/ flashing then it is an indication that tv got problem and tech visit is needed to sort out problem.
Thanks.
Apr 20, 2011 | Sony Televison & Video
How to fix a sony trinitron tv 42 inches with serial number 9022194 when yuo turn it of not turn back on for few days and the light blinks 7 times
it needs new pcb relays they are the main fault in the sony trin systems very common fault but they dont make the parts anymore so you will have to find a tech shop that has them left over from surplus orders
best of luck
Aug 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red light blinking 7 times on Sony Triniton Wega TV
This means one of three things, either the lamp is bad on your tv, the ballast that powers the lamp is bad or the safety switch for the lamp door is not depressed or it has come un-plugged. It could also mean the power supply or fuse on the power board is blown. I am assuming this is a DLP tv, and if so, it is fairly easy to fix it or find parts for it online. If you are slightly mechanically inclined, want to save money and dont mind paying attention to detail then you can fix it yourself. If you need help dont hesitate to ask.
Jun 21, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
I have a sony 52" tv model kdf-e55a20 dont start up
Probably lamp. usually powersupply will give the first click but not the second to power up the lamp. there is no horizontal fix for that type of tv
Jun 02, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv turns off
how old are ur tv...i think the best solution is to send it back to the electrical shop and let them fix it for you...
Oct 25, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony blinks 6 times wont turn on...is it worth fixing
replace on the D board
IC6501
IC8002
C6510
C8027
C6532
C8037
Hope this fixes you, if not then alot of other might get theirs fixed. please leave your feedback!
this fix cam from sony tech just 5 minutes ago.
FIxes problems with tv not turning on when cold, very hard to turn on. or people that have to unplug and plug in again to get it to come on. I usually dont give info like this for free as I'm a head tech.
good luck
Jun 26, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony big screen tv, no color
focus block or neck boards on thr picture tubes
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
