I have a Xerox 8500. The info page it prints when it starts up says it is 8500N, but the unit itself doesnt say N anywhere on it. I would like to be able to automatically print on 2 sides. Can this printer be upgraded to 8500DN? Do I need to purchase new hardware?
  • Sean Loeffers May 29, 2009
    I saw a forum that said a config card could be added, but no one seemed to have that working so I wasnt sure that it was possible. Thanks for saving me from buying that config card!
  • 10,515 Answers
These are 2 different models.
8500 series
8500
8500/N
If it's prints with 8500/N, it confirms you have 850/N. Now upgrade to 8500DN is not possible.
You need to purchase a new printer. There are so many kits available but there is nothing to convert 8500/N to 85DN.
If we talk about print on 2 sides automatically, its known as "Duplex Printing".
It's only possible on 8500DN.
On 8500/N, it's possible but manually.
You would find many forums and information that would force you to buy configuration card and so on, but to be honest nothing would work.
I hope this would help you a lot.
Thanks for using "Fixya".
Do rate the solution as "Fixya' if 100% satisfied.
Posted on May 29, 2009
Xerox phaser 8500 fault 37,018.45:7725
37,018.45: Head Maintenance Clutch Disconnect. The Head Maintenance Clutch is not drawing the expected power from the supply.
You'll probably need service.
Jun 20, 2010 | Xerox Phaser 8500N Printer
Hi there i can no get my Xerox Phaser 8500N to print color what can i do?
Are you using Windows 7? If so, this is a known problem.
The xerox website says to uninstall the printer and reinstall with the correct driver, but this did not work for me.
Apr 20, 2010 | Xerox Phaser 8500/DN Printer
We have a Xerox Phaser 8500N printer. The yellow is printing out a dingy gold. I hav checked the yellow print blocks and there is plenty.
What it essentially boils down to is that you're not printing enough color. The blocks are melted into a holding bin and will discolor over time. To correct this, you will need to purge the color that is "stale". Go to this link http://www.solid-inks.co.uk/technical_support-phaser_850_860_8200.html?category_id=1 and download the pdf for your color (I would recommend downloading all four to keep on hand). You'll want to open the PDF and print 10 to 20 copies until the bad ink is replaced with fresh ink. You'll notice the color change as the ink is purged.
Jan 05, 2010 | Xerox Phaser 8500N Printer
Phaser 8500 on power up it prints a startup and 89 pages of junk
You cannot turn off the start up page on this machine. The special character pages are called a post script error. You could install a PCL driver for the machine or try changing some settings in the Driver to "RAW". Use the link below for any other questions.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_8500_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_8500_8550):str(8500_8550),question=ref(ProdFamily):str(Prod_8500_8550),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:8500_8550,varset=prodName:%20Phaser%208500/8550
Feb 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox 8500 excessive ink use
One of the reasons this could be happening is because you are using non-xerox ink so your print head needs to clean it out much more often. Be careful using other ink as this can destroy the machines printhead which is more expensive then the machine itself to replace. What you could try is installing the new printhead firmware, it might help! Follow the link below and good luck!
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8500_8550&country=United%20States&language=en
Niallbt
Jan 09, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
You have to go into Diagnostics. Once in Diagnostics arrow down to function menu.
Then select
Then arrow down to ClearISCfaults hit OK
follow instructions on screen.
Nov 24, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500 does not turn on at all
Most likely the electronics module has gone bad.
Sep 11, 2008 | Xerox Phaser 8500N Printer
Phaser 8500N color problem
There is a process called TEKCOLOR correction.
It is on the xerox.com site.
Search for phaser 8500 under the support, in support in the search area enter.
Solutions for Colors are Off or Wrong
This will take you through the process in the correct steps to resolve your issue
Nov 07, 2007 | Xerox Phaser 8500N Printer
Phaser 8500 cleaning page
You can't. Just simply stated. It is the way it's designed.
Per Xerox below
NOTE: The automatic printhead cleaning cycle cannot be disabled.
The printer performs automatic printhead cleaning cycles to remove air bubbles or foreign matter that can cause a printhead jet to malfunction. An automatic printhead cleaning cycle is performed when the printer is first powered ON, or if the ink has cooled to the point that a cleaning cycle is required.
Powering OFF the printer longer than 3 or 4 minutes will also cause the printer to perform a printhead cleaning cycle when the printer is powered back ON, which uses ink. To minimize ink consumption, keep the printer powered ON at all times.
Sep 13, 2007 | Xerox Phaser 8500N Printer
I can't get rid of the margins when i print something
I'm guess you are printing from MS Word? Click File the "Page Setup" Click the layout tab the far right then go to the bottom and click borders and select the NONE option. You should have your borders removed!! =) That is if that is the type of border you are talking about.
Cheers!!
Feb 11, 2007 | Xerox Phaser 8500N Printer
44 people viewed this question
k24674
jasbo
jasbo
