Question about Whirlpool GC5SHEXN Side by Side Refrigerator
Optical sensor or valve problem
My Ice Mker is not filling with water.  the fill tube does not seem to be frozen.  I am wondering how to determine if the optic is out.  It continues to blink and pause, even with the unit in the off position.
  • 1 more comment
  • wtmahoney Oct 23, 2007
    I will test the solenoid.  Thanks for you insight!  I have removed the ice maker and I think I have tested the various elements and they appear to have the correct readings with the tester.
      What do I do to test the solenoid?  How to I ensure that the ice maker is asking for water?  Open and close the flapper?
    The water valve is working. could I switch the hoses?
    I am thinking of removing the filter from the loop. As I havean RO system in the line.  Any advice?
    Thanks again!
    WT
  • kgsfv Nov 14, 2007
    new refrigerator,- ice maker is not producing ice. water dispenser works.
    red sensor light blinks twice and pauses.
    no water in solenoid on the back of the refrigerator
    Please Help
    thx kk
  • dryan82 Nov 28, 2007
    My Kenmore, Model 106.56549400 has the same problem. Only my lights do not come on at all for the sensor no matter if covered or not. The tray will not fill with water either but the water dispenser in the door works like a charm. I am wondering what the issue may be.
  • Whirlpool Master
  • 4,655 Answers
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Posted on Oct 23, 2007
  • John Tripp
    John Tripp Oct 23, 2007
    If you switch the hoses this may also help but confuse and cause a mess. One solenoid controls the water dispenser and the other the ice maker.
    Temperatures of, 7 degrees f. and lower, an unobstructed optic beam, an empty ice tray will trigger,
    ac voltage of 24v to 120v to the solenoid. A simple and safer way of checking the solenoid is to place a metal screwdriver to the top and center to feel a magnetic pull on the screw driver. But if the plunger inside is stuck it will not open and allow water to flow. Unplug the two wires and re-plug and listen for a clicking noise or have someone ohm the solenoid coil to make sure it?s not burned out. Replace the filter because that?s always good for the water, you and refrigerator. When the ice tray is removed the flapper door acts as a turn off to keep the water from flowing to prevent flooding of the freezer, so have the tray in place and the beam on to tell the water solenoid to open. Hope his gets you going.
Whirlpool ice maker will not fill with water
1st check to see if fill tube is frozen that goes through back freezer wall to feed water to ice maker. If it is, thaw it and replace water valve. If not frozen, then you must determine if water valve or ice maker is bad. You must determine if Ice maker is sending voltage to valve. If it is, replace valve. If it's not, replace ice maker.
Sep 03, 2017 | Whirlpool Refrigerators
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
Ice Maker not making ice cubes model # FRS26FCDW1
Remove the cover on the front of the ice maker and you will see a large gear with a Phillips screw in the center. Use a screw driver (phillips) and rotate it clockwise. It will start to rotate on its own and should make a revolution and fill with water. If it does replace the ice maker. If it makes a revolution and doesn't fill with water, make sure the fill tube is not frozen, and if it is not frozen. advance it again and determine if power is getting to the valves.
Feb 17, 2015 | Frigidaire Refrigerators
Our icemaker is filling the tray with water while it is still turned in a down position to dump the ice into the buck. How is this problem resolved?
ice maker calls for water at the 11 oclock pos and only for a few sec .. it cannot dump at this time becaus it's not frozen . if it is filling with water at a different pos like 6 or 3 oclock the the timing is off and you may need to repl ice mker . mm
Aug 17, 2010 | Liebherr Refrigerators
I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Not getting water to icemaker but have water in door dispenser
no water to ice mker / look at the water valve in the back it is a two sol. valve one side for water and other for ice .. also the tube in back of freezer that fill the ice mker may be frozen .. ( hot water up the tube will open it .. mm
Nov 30, 2009 | Dryers
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Whirlpool GC5SHEXN Side by Side Refrigerator Logo
859 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
