Question about Brother Sewing Machines
Siezed motor my HE 120 just locked up. I can't move the needle at all it's like a seized motor. what do I do with it? Am I supposed to oil it or something?
  • tamis4 May 30, 2009
    Thank you for your quick responds to my question and I will definitely try what you suggested. Again thank you.
  • 15 Answers
Well, AC/DC motors do "seizing" quite well in fact.
If you were supposed to oil it prior to the failure, they most likely will not work now! (Bearings are shot)
BUT.....Lady Luck is always hiding, so you never know.
Tear that dude down, and give it some 7-in-1 oil. Spin the motor BY HAND. See if she will "free spin". If she feels like a 6 year old fighting a catfish, it will be a "no go, no fix".
But if she WILL spin after that......give her a couple of drops extra, put it back together, and see how long she lasts.
And then keep on oiling it.
Granted, I can't tell you exactly WHAT seized your sewing machine up, OTHER than motors are motors, and bearings fail when they get dry. In this case, you might get lucky!
Posted on May 30, 2009
The needle on my singer touch tronic will not move. Does it need oil. How do I do that?
I believe that is an older mechanical machine. If it hasn't been cleaned and thoroughly oiled recently, most likely it is seizing because the moving parts are frozen. Refrain from trying to run the machine until you get the issue the addressed or it may damage the machine and/or motor.
Wheel on right side that controls the needle up and down is very tight...
Jul 23, 2017 | Singer Sewing Machines
Should I oil the motor on a kenmore sewing machine model 158.905?
Do NOT oil the motor unless the manual instructs you to do so. (Sears carries manuals for most of their machines.)
Your machine appears to be an older mechanical machine. As such, oiling would be necessary for the moving metal parts. The following may be helpful to keep your mechanical machine happily operating. (Although the following is for machines that have seized due to lack of oil, following the procedure is helpful in preventing the machine from seizing.)
May 06, 2017 | Kenmore Sewing Machines
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
Hi, I just got a Necchi #537FA it has never been used , however it has sat for some time the light comes on ,the belt runs, the bobbin will run but the nettle seems to be locked up will not move
It's an older mechanical machine that has not been used for a long time and probably has not been cleaned or oiled. It is seizing from old dry oil. Avoid using the machine until it has been oiled or the motor could be damaged.
Mar 16, 2017 | Necchi Sewing Machines
Have new never used singer simple 3232, tension was tight n I tried to use it n locked asap hand wheel/ pedal frozen needle wont move. no thread is apparently at fault. How do I proceed?
Return it if you can, I have seen these brand new with seized needle bars before. You can try putting a drop of oil on the needle bar where it goes through the supports and gently working the handwheel until you can get it moving.
Jan 04, 2017 | Singer 3232 Simple Sewing Machine
What could be the cause for severe resistence on the motor when the machine is set for sewing. it works fine for bobin loading.
Depends on your machine (no make/model provided). If it is a vintage machine, frequently they seize due to lack of cleaning and oiling. The old oil solidifies and locks up the machine.
It was working now it seems to be frozen the needle part wont move
Mar 22, 2016 | Sewing Machines
I have a homemaker FY2300 sewing machine and it has seized it will only move enough for me to thread it but will not move after that. HELP
As complicated as they look, they are actually fairly simple in their operation. I know parts can wear out, but that is usually indicated by a gradual decrease in performance and an increase in noise. If a machine has seized it is usually for one of two reasons. It has jammed with dust and fibres from material or the timing is all wrong.
Open up and have a look at the inside of the machine and remove any bits, dust, threads etc that are accessible. It will benefit from oiling as well, but unless it is rusted it should move fairly freely by hand turning the wheel on the side. If it does move now check that the needle is going up and down and doesn't contact anything whilst turning the hand wheel. The needle tip will drop below into the shuttle but shouldn't touch anything and should come out again before the mechanism moves to block the needles travel. Do this for a few cycles and if it operates freely then put a drop of oil in the lubrication points.
If it is totally seized or the needle hits something then maybe a professional can help with a service.
Oct 08, 2015 | Sewing Machines
Cannot turn hand wheel or sew.
Have you checked the bobbin compartment to make sure there isn't a thread-jam there? It can get so tightly snarled that even the handwheel won't turn.
Aug 08, 2017 | Sewing Machines
The motor on my huskystar 207 has seized up.
Needle broke then it seized? Could be any number of things from a bent upper arm to a motor that needs servicing. I recommend you take it in for professional repair.
Sep 15, 2012 | Husqvarna Huskystar 207 Sewing Machine
Sewing Machines Logo
214 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
