Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Elite Top Loading Washer with multiple errors
Machine has worked fine for over two years. The other night we hear beeping from the laundry room and discover all of the codes scrolling the screen, dial lighting up, water cutting on and off on its own. Unplug for a day and plug back in, it is fine for 12 hours then does it again. Assume the main board is going.
  • mtroutma Jun 01, 2009
    was able to run several loads through it today after pressing all of the buttons and dials. Have a feeling something might have been stuck on the keypad - time will tell if this fixed it.
  • 15,935 Answers
Yes - replace the ECU/Controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
L4 error message on my Kenmore top loading Oasis washing machine?
call 21-341-0097 maytag service with model number aval and i can help you. it is poss you will need a repairman out and we also come to homes in the dfw area and east of dallas. we are a service provider for whirlpool/maytag.
Dec 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Washer 110.2709
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Elite Top Loading Washer with an F2 error
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
The F2 error code on this washer indicates a stuck button on the user interface control board. The procedure for accessing the control boards on this washer is shown in the image below. I recommend unplugging the washerand checking the wire harness connection from the user interface control board to the machine control board. Try unplugging the connections and then plugging them back in a few times. Make sure that they are plugged in correctly and then reassemble and test the washer. If the F2 is still displayed, then the user interface control board will need to be replaced.
CLICK ON THIS LINK TO GET THE INSTRUCTIONS HOW TO REMOVE CONTROL BOARD:--
http://media.fotki.com/1_p,wfbgkftgqtgssggxgtqsskgwtqkq,vi/gdqwksfbdxggskbksbb/1/1303472/5961857/image8028img-or.gif
You can order a new user interface control board from the Sears PartsDirect website or from----------
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jan 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
F2 and beeping
The F2 error is the user control board gone south on you, a new board will fix the machine, as always do you own your home and does the insurance cover appliances?
Sep 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE (2706?)
I just found out sears has a recall for the control board for the top loader. I have the same problem. I called and to my suprise they said the swap was free. 1-800-659-7026. Have your model and serial ready. located under the door. This problem has been extreemly irritating for months now and I am sure sears is still collecting huge repair bills from people. No more sears products for me either!
Jul 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
165 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
