Question about Kenmore Washing Machines
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
Our kenmore wont spin and makes a grinding noise when the spin cycle supposed to be spinning the water out.Please Help with any suggestions.
Sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
Posted on May 29, 2009
  • d386 May 29, 2009
    check the switch a the lid opening. there should be a slot so when the lid is closed a plastic or metal clip goes thru the slot and activates this switch to let the washer spin and locks down the lid. switch could be bad or broke.
2 Suggested Answers
  • 1937 Answers
SOURCE: My Kenmore 80 series will not spin and is making a grinding noise
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Three possibilities:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
It's also possible that the Neutral Drain Assembly in the transmission is broken:
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Ours had a similar problem.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
All of the above sound more difficult than they really are. If you're comfortable with a socket set, pliers/vice grips and willing to get a bit dirty (oil) you can save some considerable money.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Apr 23, 2010
My washer makes a buzzing sound when trying to go through spin cycle. Cold water doesn't work either but other temps do.
check for a faulty cold water solenoid in the machine
the buzzing noise is a cycle frequency noise caused when a solenoid coil is faulty and not moving the centre bit.
May 28, 2015 | Washing Machines
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer is full of water and agitating clothes. it will do nothing else. i have tried to switch to other cycles or rinse cycle, it stops. makes no noise whatsoever and the washer is full of water.
Most typical thing wrong when a washer agitate but wont drain/spin is a defective lid switch. Reply back w/brand and model number and ill tell you where yours is and how to check it.
Aug 06, 2011 | Washing Machines
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
GE WBSR3140D
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
Washing Machines Logo
348 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
