Question about Nintendo Super NES Console
COnsole trouble for SNES
I insert a game into my Super nintendo. I turn on the console, but nothing shows on the TV, even though everything is plugged in. What should I do?
    Problem Solver:
  • 12 Answers
Just use a norbal cotton swab and rub the game connectors, as blowing damages the game over a period of time.
Posted on Nov 30, 2007
  • 47 Answers
The old school gamer. :-)  Love it.  The plow in the bottom of the game.  Then try.  This normally works :-)
Posted on Oct 27, 2007
Sounds not working on super nintendo
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.well I guess that you will have to hook it up to a DVD player or a VCR player to have it work on a digital tv
Note: pictured above is the original Super NES. The redesigned Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the VCR.
Place the yellow end of the Stereo AV Cable into the Video "in" on the back of the VCR.
Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono VCR with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV Cable into the "multi out" connector on the back of the Control Deck.
After system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward Game Pak).
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen. You are ready to play!
Recording Game Play
Set up the Super NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 31, 2013 | Nintendo Super NES Console
SNES games are tinted green on TV
Well you could try and fix it then.
Apr 23, 2010 | Nintendo Super NES Console
I have turn on the super nintendo but nothing happens my t.v. screen just goes to a black screen, the power is on and I have change the cord, is it possible that they system itself have finally give in?
if you can't even get the main screen of "Nintendo" to show up then it probably is a problem with the video cable. make sure the cable ends and the ports on the tv and consle are clean and connected properly. if that doesn't work then the cable is defaulty or the system isn't putting out a signal.
Jul 31, 2009 | Nintendo Super NES Console
Black Screen
It might be your AV cable or the connector for the cable. Try it on another TV just to make sure its the SNES though.
Jun 30, 2009 | Nintendo Super NES Console
My nintendo light comes on but the screen stays blank
Clean the control deck and the cartridges. Check the input cable to the TV.
Hope this helped :)
Oct 26, 2008 | Nintendo 64 Console
Video Problems with Super Nintendo
Try replacing your video cord. Sometimes they are just "patially bad" meaning they can read something but not enough to do anything.
What did you use to clean the games?
Aug 04, 2008 | Nintendo Super NES Console
SNES doesn't display?
The CIC chip, also known as lock out chip, may have gone bad. Here is a quote from a site I found.
"Every SNES control deck has a regional lockout chip (known as a CIC), as does every original SNES game cartridge. Before a game is loaded, the console will attempt to communicate with the CIC chip on the game cartridge. If the CIC chip doesn't respond or does not correspond with the consoles CIC, the console won't load the game. In most cases, a black screen is displayed."
http://www.chronicgames.net/articles/snes-museum.aspx
Yea basically I am having the same prob with my system and I am trying to fix it. Ill let ya know if i figure it out
Jun 14, 2008 | Nintendo Super NES Console
I have a paly station Nintendo
you may need to check if your game has been inserted properly.
May 13, 2008 | Nintendo Super NES Console
Super Nintendo won't show any picture or sound even though it reads a signal.
Try pushing down and back lightly on the cartridge while turning it on.Used to work for me.You can also clean the game contacts with rubbing alcohol.Hope this helps...
Feb 20, 2008 | Nintendo Super NES Console
Nothing on the TV when I play Super Nintendo
it has to be the av connector as if you are turning on the console something would flash on the screen in any case
Jan 17, 2008 | Nintendo Super NES Console
Nintendo Super NES Console Logo
113 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
