Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears 1/2hp thinks it is not all the way up and will not go down
After some storms I opened the garage door and it went up fine, tried to close it and nothing happens. It just makes a clicking noise, the gears, and everything mechanical is working properly- Is it the logic board that needs to be replaced? Sensors are aligned I can stand between them and hit the button and the lights flash on the opener.
Can also manually lift door.
Any help appreciated
thanks
kevin
    President:
  • 3,197 Answers
It is really a common problem for lightning or electrical surges to take out the logic board. Big expense too.
Posted on May 29, 2009
Champion Liftmaster Garage will not open or close. Just clicks
Pull the logic board and check for burnt or missing traces on the printed circuit. I would guess at an estimate of $125.00 but don't even know where you live.
Aug 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
The sensor lights are steady. The opener cycles fine withouit the garage door connected. Everything worked fine until yesterday. I hit the open remote and the garage door did not open. I hit close and it...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. Also check the door springs. One of them could be broken.
May 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door not opening properly.
Check the springs on your garage door. If one is broken, the opener will not have enough power to raise up and it will stop like that.Or the up and down limit settings have gone off or bad.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not close garage door talk to tech of manufacturer who thinks it the circuit board insise the unit i can buy the board locally just need to know hwo to replace the opener is made by...
I TRY TO CLOSE GARAGE OPENER DOOR DOWN BUT IT REFUSE TO CLOSED DOWN BECAUSE SUN SHINE TO SAFETY REVERSING SENSOR, LIGHT BULB BLINK ON , WHAT SHOULD I DO IT ? PLEASE EXPLAIN ME HOW TO DO IT? THANK YOU . TRULY HAROLD MILLER ,
Nov 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener closes when closed
Try this: Loosen the chain enough that you can remove it from the sprocket above the motor. Now run the opener until the sprocket turns in the clockwise direction and stops. Reconnect the chain. This will get everything in sync and you will have to tweak the 'up and down limits' a bit to get it just right.
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
No reponse when using the remote, the wall control works fine.
The remotes use a receiver to actuate the door and the wall control does not. It sounds like your logic board is bad. Maybe a lightning storm recently? Try removing the board and look for burnt or missing traces on the printed circuit.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door went up, now won't go down
take out bolt from rail that trolley is stuck against. try it now. happens sometimes
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
136 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
