Question about UPS Battery Backup Systems
Starting UPS Not able to start UPS - keep getting error no. 2418 but cannot find how to correct this error. When PC switched off computer clock loses time and now goes back to 2001!!!
  • 4 Answers
Re: Starting UPS
Hi, guies
                 First all of  look in battary condition of ups, and that
battary sencing voltage circuit
 In your second case, please replace lithium cell with same and reconfigure the bios setup
Posted on Oct 24, 2007
Re: Starting UPS
If your computer time keeps resetting, the CMOS battery on your motherboard is bad. It's a flat, quarter-sized battery plugged into your motherboard that you will need to replace.
Posted on Jul 08, 2010
0 characters
3 Points
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
Error code ac
check startup sequence, at what stage you reach the fault?
Dec 12, 2013 | MGE UPS Battery Backup Systems
Constant alarm but works fine otherwise
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website:
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
My ups won't stop beeping
The beeping on your ups is the sound of an alarm it will come on when starting up due to slow start circuit, there are a reset switch on the front display press once and beep will despair.
Aug 19, 2012 | UPS Battery Backup Systems
When switched the bypass to normal position, voltage failed through the unit; however the QB3 position gives output voltage
You didnt start the UPS correctly because the static switch was not on. The Static Switch has to be on to get a clean transfer of power. Check your static switch
Sep 14, 2011 | MGE Galaxy 3000 UPS System
After switching on the power supply, my pc takes around 3-4 minutes to start with APC UPS, earlier it was responding within half a minute
Have you taken it off the UPS and tried connected direct to an outlet.
Does it take the same amount of time?
If so you have a software or hardware conflict that is new and needs to be researched carefully.
try using the windows error log to see if there any startup errors.
Nov 26, 2009 | APC Back-UPS CS 500VA UPS System
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
When I boot my PC up I get a blank screen and a message saying no signal then the screen goes into standby mode
OK, it's gonna be one of these 3 things :
1. The cable linking your CPU to your monitor might not be properly plugged or has been damaged. You should hence ensure that the connection between the two devices has been properly done and that the cable’s state is fine.
2. You might be facing a problem with your monitor if the CPU makes a single beep error sound when you switch on the system. You can check whether the problem comes from your monitor by testing it on another CPU. If you still have “No Signal” error displayed including the error beep, I would strongly suggest you to try to get your monitor fixed by a competent technician or to get a new monitor.
3. If you receive several error beeps when starting the computer, this might be linked to a graphic card dysfunction. You can refer to the motherboard notice or check that the connection has been properly set
Dec 12, 2008 | UPS Battery Backup Systems
UPS Battery Backup Systems Logo
134 people viewed this question
Top UPS Battery Backup Systems Experts
Jax Planet
Jax Planet
Sudeep Chatterjee
Sudeep Chatterjee
Are you an UPS Battery Backup System Expert? Answer questions, earn points and help others
