Question about Pioneer GM-5200T Car Audio Amplifier
POWER I have a pioneer gm-5200t 760 w amp, and when I turn my stereo on, the power light blinks on and off constantly, and no there is no bass.
  • angeleyezz75 Jan 17, 2008
    I am having the same problem. I have replaced all the components. I bought all new cables, i replaced my stereo... even went as par as getting another amp which i returned because i had the exact problem as before. The amp lights up but all i get is a flickering and no sound from the subs. I have checked all the wires and fuses. Not sure where to go now???
  • angeleyezz75 May 11, 2010
    I am having the same problem. I have replaced everything cables, radio, bought a new amp.....i am having the same problem. Amp light comes on but flickers constantly and there is no resulting sound coming from the subs. Please help me... not sure where to go from here
Short in the system, or bad ground, or connections?
Posted on Oct 23, 2007
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
I have a Pioneer GM X862 car amp, with a constant red light on it. Also, it is supplying the subs with power, they are lightly vibrating but its not pushing like it should. No bass.
Make sure your power line comes directly from the battery and that iyt has no abrasions or cuts in it. Check your ground and make sure that it has a good connection to the vehicle chasis. Ensure that the remote line is connected properly to the remote lead from your head unit/receiver.
Common mistakes in this area are using the remote turn on lead as a power lead. It does not have near enough power to drive the amp so you will only get a slight trickle of power.
Jake
Oct 02, 2010 | Pioneer GM-X862 Car Audio Amplifier
Pioneer GM-6200f amp no audio - flashing light
Hello! Yes, It certainly looks like the output power circuit has blown.
I wish I had better news.
Guru................saailer
Jan 12, 2010 | Pioneer GM-6200F Car Audio Amplifier
Subwoofer pulses
amp is probably bad. i call this "motor boating". especially if it is a constant pulse. 9 times out of 10 the amp is the problem with this. rarely is the radio the problem.
Dec 26, 2009 | Pioneer GM-5200T Car Audio Amplifier
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amp worked the stoped...
check every connection with a volt meter to see where u r losing power
Jul 04, 2009 | Pioneer GM-5200T Car Audio Amplifier
No sound from amp
THIS IS AN EASY FIX. DISCONNECT THE POWER WIRE FROM BATTERY. REMOVE THE GROUND WIRE FROM THE CARS BODY. SAND ALL THE PAINT AWAY FROM THAT AREA. WIPE IT CLEAN WITH A DRY CLOTH AND HOOK THE GROUND BACK UP. THEN RECONNECT THE POWER WIRE AND THAT SHOULD FIX IT. IF NOT THEN TURN DOWN UR GAIN CAUSE THE AMP IS OVER HEATING
Feb 19, 2009 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-5200T problem
i dont think transistors are bad . you should check the amp controlls they may need adjusting
Jan 20, 2009 | Pioneer GM-5200T Car Audio Amplifier
Red light on my amp?
Does the amp power up normally if you disconnect the speaker wires from the speaker terminals of the amp?
It's never a good thing to blindly short across a power source.
May 22, 2008 | Pioneer GM-5200T Car Audio Amplifier
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-5200T Car Audio Amplifier Logo
208 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
