Question about GE Dryers
Dryer won't start after I slammed the door
I kind of slammed the door and then it wouldn't start up again
    President:
  • 1,489 Answers
The door switch is probably in the next room somewhere.
Look in the hole around the edge of the dryer opening. There should be a switch in there. It's most likely been pushed back so the door post/actuator does not engage it.
Switch need to be put back in place.
Posted on May 29, 2009
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
Aug 07, 2014 | Magic Chef CYG4000AWW Gas Dryer
My ge front loading gas dryer turns off when there is still time left, to start it again i slam door, whats wrong?
You may need a new door switch. Check the wire connections and be sure the switch is secured.
Jan 20, 2013 | Dryers
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
Maytag Neptune door won't lock, or start the was cycle.
check all wiring for tightness and any corrosion from door latch up to the central control unit first,if ok then replace door latch component as this part wears out quickly you will need to remove washer top,then door boot spring to release door boot from door frame to access wiring to door lock component
May 06, 2012 | Maytag MDE5500AYW Electric Dryer
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
The dryer would not start, it was dead, opened and slammed the door shut, it worked fine. 2 days later it went dead again, sounds like the door switch, any ideas?
Sounds pretty good, actually. Insert screwdriver on either end of bottom/top panel and lift. Find the door switch and bypass it for a quick fix (just remember that dryer will operate when you open the door - not recommended if small children are present in the home). My advice is to replace the switch.
Nov 16, 2009 | Estate TEDX640JQ Electric Dryer
Dryer won't come on
Was it the dryer door he slammed shut or the house door? If it was the dryer door, then TheMobilian's answer is on the nose. If it was the house door that was slammed and it tripped the circuit breaker to your house, then you have something else entirely going on. Does your dryer have an electronic control panel (totally smooth surface), or does it have the knobs and buttons? What model number do you have?
Jul 08, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won't start unless I slam the door
Not normal. Check door switch. As a test you can jump it out to see if the dryer works then. if that does not help then , I i would consider replacing the starter switch.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryers Logo
125 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
