Question about Samsung HCL4715W 47" Rear Projection Television
Green out of alignment on samsung rear projection tv
Hi my samsung rear projection tv has an alignment problem with the green. I'm an electronics apprentice but don't do tvs. if you could give me a more specific idea of what was wrong before i start fault finding without a service manual it will save me alot of time and would be greatly appreciated. Cheers Luke I have a 42" Samsung ST-42W5P rear projection TV that the RED alignment is out on. I am a RADAR technician but really haven't ever worked on TV's all that much. Definitely have never worked on rear projection types of TV's. Can you point me in the right direction?
  • kaheinz57 May 29, 2009
    Can you dumb that down for me a bit? Where would I start? I don't have a service manual and have no clue what is what in there.
  • 431 Answers
Hi luke I am in the uk and not familiar with this set is it a three tubed crt television or an lcd projector type .. either way what you are descibing is convergence ( three primary colour guns all pointing at the same spot in a nutshell ) in the case of a crt projection tv three tubes one red one green one blue .. there should be a convergence pattern in the menu to re set the convergence via the remote check the manual . If it isn't adjustable you may have a scan coil fault or a tube ie : green with low emission check the green colour gun transistor and associated circuit for leaky caps resistors that have changed value or transistor leakage .. and don't forget the ever popular dry joints on the scan coil plugs .. hope this helps Vortash
Posted on May 29, 2009
  • 585 Answers
For the set to have two STK392-XXX parts. one is probably failed,and may have also fried a 1-watt resistor close to it. If you do a search for the datasheet for the part, you should find a partial schematic in the typical applications for the part. It should be enough for you.
  • Bruce Volkers
    Bruce Volkers May 29, 2009
    Look for a "convergence board" as the parts in question will be located there. The board is behind a removable front panel in some TV's
LOOK for 3 parts that start with STK (BLACK THINGS THE SIZE OF A MATCHBOOK) then replace all 3 (ebay) also look for some green coils that may be burned. If you SEE THE STK's then your in luck, as 95% of them are bad.. Please rate!
Mar 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Red a green shadows on most objects!
use manual convergence to re align the colors. the owners manual tells you how to do this. No manual go to samsung. com in the FAQ section
Oct 11, 2008 | Samsung HCL4715W 47" Rear Projection...
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
Green Shadow
Sounds like your green panel is out of alignment. Has the TV been moved or jarred recently?
Generally speaking rear-projection panel alignments need to be done internally by professionals. Check for a local TV technician that specializes in projection TVs.
Apr 07, 2008 | Sony KP-43T90 43" Rear Projection...
HCM4215W Green convergence problem
Hi Greg,
Sounds like you have a bad convergence chip in the convergence board. Unfortunatly, about 80% of the rear projection sets I work on have this similar problem. I suggest that you change both chips ( there are 2 of the same ) and remember to use heat sink compound as this is why you not have the problem ( excessive heat destoys electronic components). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung PCL541R conversion alignment
move the blue and the green to the red till they turn white.
good luck
please mark the post with a fixya!
Dec 15, 2007 | Samsung PCL541R 54" Rear Projection...
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
42"Samsung HCN4226WX/XAC
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Oct 09, 2007 | Samsung HCN4226W 42" Rear Projection...
TOSHIBA REAR PROJECTION TV 42H81
FIRST DO MANUALY (THE ALIGNMENT OF CRT'S)
May 12, 2007 | Toshiba 42H81 42" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
325 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
