Question about Boating
My motor will not stay running
It starts right up, runs for minute dies, starts right back up runs for minute or two dies, so on so on........
  • Dean
    Dean May 11, 2010
    Is the breather on the tank open?
    Guru:
  • 597 Answers
Most common problem here is fuel. It either has condensate or water in it or the fuel filter needs changed. Something may also be blocking the line from tank or a kink in line.
Posted on Jun 01, 2009
Battery will stay charged
Have the battery charged and tested and then test the charging system. You should never run a car with a very dead battery. that will burn out the alternator.
Sep 14, 2013 | 1996 Buick Century
1996 ford f-250 starts runs a few minutes and then dies
will it start right back up? could be fuel filter or pump
Oct 20, 2012 | Chevrolet Cavalier Cars & Trucks
When the motor is cold and the outside temperature is below 70 the car will not stay running. Will die with in 30 seconds or so of starting, then you have to wait a minute or two befor the car will start...
Are there any service engine soon lights on associated with this problem?
Possible CTS (Coolant Temperature Sensor) or another sensor giving faulty data for the cool air temperature.
Check spark and gas delivery when cool, below 70 deg. If the spark is not being delivered or the fuel injectors are not delivering fuel at this temperature, it will explain why it doesn't run right until it is warmed up.
Oct 08, 2010 | 2001 Ford Windstar
The 96 park avenue will start great and run great. No security light comes on and everything runs smooth. No bucking or hesitation. A great ride. Then all of a sudden it will die. Lights stay on and radio...
It cannot be the VATS system. The TDM, that is the core of the VATS system, is engaged only at the time you start your car. I have a problem exactly like yours on my 95 LeSabre and just discovered it is the alternator that sometimes charges and sometimes doesn't and when it doesn't, the battery's voltage goes lower than a certain threshold and the computer (PCM) is unable to work anymore and shuts down the engine. Took me months to discover this!
Dec 29, 2009 | 1990 Buick Reatta
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
CAR WON'T STAY RUNNING
when key on and engine off, does the security light flash constantly? if so its shutting down the fuel pump, it starts momentarily due to the computer priming the engine with fuel. how to reset, turn key to run position, leave it on touch nothing, takes 10-12 minutes, start watching light around 10 minutes. it will stop flashing... turn key off, then back on and start this will reset the security system. they are sensitive on this platform car it will happen again. good luck!
Sep 05, 2009 | 1999 Pontiac Grand Am GT
Blower motor runs but dies out..
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
Apr 08, 2009 | Amana PTH153B50AJ Heat Pump Air...
did you check the volts? and the amps.
Apr 08, 2009 | Amana PTH123B25AJ Heat Pump Air...
Battery light on, takes forever to start then dies once started
if you can get the car started again and with someone helping you have them take the positive side of the battery cable off while it is running and if it dies then it is the alternator also check your drive belt and when was the last time it was changed because it could be slipping
Jan 05, 2009 | Lincoln Mark VIII Cars & Trucks
Boating Logo
198 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
