Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV would turn off by it self and make a cracking noise. Looked in the back and saw an arc from the lower left.
Tv was turning on and off on its own. I tried to unplug it for four hours and see if the safety mechanism would reset. When i turned it back on i heard a noise and saw an arc coming from the back left. I took off the cover and saw a burn mark on the bottom left card.
  • 21 Answers
Resolder and it will work perfect.
Posted on Jun 01, 2009
Cracks and pops when turned on and will flash light across screen at times.
That could be a number of things that would make that noise, Have you removed the front panel screen in front on bottom and try turn TV on Look for Spark? Bad anode button on one of the tubes can cause that, bad flyback transfomer.Have you removed back and look to see if arc is coming from the FBT Mounted on Deflection board. First board on the left is the deflection board.
Mar 18, 2015 | RCA D61W20 61" Rear Projection Television
Affinity aeq6000es2. After two cycles of the
sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Jul 19, 2010 | Frigidaire Dryers
My 27" wega was making a crackling noise when I turned it on. Last time I turned it on it made a pop and went to standby, it blinks three times, pauses then blinks again clicks and blinks four times.
pls. check your tv mains plugh is luss canaction
if not then
probulum is in side tv set so pls. dont.use tv again and cont.nearest tv tech.and solve this problum. becous cracking noise is dengered for your tv.set
* you dont. open tv back cover it your self.becous in side tv set very high voltage.
Nov 10, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
Arcing in lower back left corner
Replace flyback transformer cost verys from 21.00 - 71.00
Jan 19, 2008 | RCA D52W19 52" Rear Projection Television
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
T.v. not coming on ,turned off by itself with an arc noise
The part is known as a flyback transformer.. it will have to be replaced.. also the horizontal ouput transistor will possible most likely be bad..
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
Cracking Noise
sounds like high voltage arcing.
Oct 07, 2007 | Panasonic PT-53TW53 53" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
