Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer showing E5 error
Started drying clothes and dryer went off after about 3min. Turned it back on and same thing happened. After about the 4th time of doing this, the dryer showed the I think its E5 error. Now it won't come on at all. Is this some that I can fix myself or will I have to call a repair person.
  • 6,784 Answers
Ok, this is a control fault. the issue is will the logic chip set on the control board. the run-time sequence is corrupt. you will need to replace the control on this unit asap if possible.
Posted on May 29, 2009
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Jul 19, 2014 | Kenmore Dryers
Dryer won't dry clothes
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
I turned my dryer on, went back to get out the dry clothes, things were hot but still wet. Nothing happens when I push the start button. I've checked the circuit, and thats good. Could it be a fuse in the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Frigidaire Dryers
Dryer will start
Try unplugging the unit, make sure the dryer is turned off before plugging it back in. If that doesn't work, see if the drum turns. If so, the problem needs a professional to fix it.
Jun 14, 2010 | Kenmore 62602 Electric Dryer
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
Dryer help
Pop the top and get the front off. Get the ball of lint out the blower housing and replace the bad blower wheel.e00d80d.jpg30eaeb0.jpg
Dec 16, 2008 | Dryers
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Sometimed error being displayed but also not completing cycles and not performing a fast spin
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Oct 27, 2006 | Zanussi WJD1667W Front Load Washer / Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
421 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
