Question about Miele Optima G2470SCVi Built-in Dishwasher
Fault code f70, drain pump keeps running, nothing else works
I have a miele optima series that has a fault code of f70 and the drain pump keeps running after the door is open. Nothing else is working. Can i fix this?
  • 177 Answers
Yes. F70 is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
Posted on Jan 25, 2010
  • brucemtull Jul 17, 2011
    Hi Taurustech,
    Am I blind? I have removed the balack kcik plate on the G2470. I have removed the 2 center screws on the middle pan and I see it is wet and dryed up.
    I see no drain pan to dry. What am I missing here?
    Thanks
2 screws in the middle, star shaped head, unscrew slide off plate. Dry , done.
Posted on Jul 29, 2011
I had the f70 code and took off the bottom pan. Looked all round and could see where the water was coming from. Then I noticed a small silver stick that I'm guessing is the temperature sensor. It has some how come loose and must have been pushed back thought the seal in the bottom of the dishwasher from the inside when I was cleaning a blockage. Pushed it back through, screwed everything back and it s now working fine.
Posted on Feb 25, 2013
I have the same problem. Have opened the front as you suggested and soaked up the water that was pushing the float disc up but when running the machine (without detergent), water reappears down below. Any idea on possible causes of water getting in? What should be my next steps?
Posted on Feb 02, 2010
  • 2 more comments
  • Miele_Man Nov 21, 2010
    Some common causes for water leaking into the bottom pan, can be: 1.) the dishwasher not leveled (front of unit is tilted lower the the rear); 2.) the temperature sensor (cylindrical-shaped and silver) was manually pushed through, leaving a hole in the bottom sump, of the dishwasher. (bottom filter must be removed to see location of temperature sensor); and 3.)water intake (water diverter path) has cracked. Cause # 2 will fill the bottom pan pretty quickly.
  • copingdad Dec 25, 2010
    F70 with the pump running happened to us each year for the last three just before Xmas. Like 'taurustech' says opening up the panel at the bottom front revealed water in the tray with the float valve making the pump run, fixed by turning off the power and carefully dabbing the water out with a towel. Yes it means water getting into the bottom of the unit and the float valve safety working as it should. In our case I think it is because my teen age children come home from university and let the garburator fill up with waste blocking the drain hose, forces water thru the seal in the bottom of the unit to the pan, disables the dishwasher for Xmas! luckily running the garburator more frequently after getting the water out of the bottom pan has fixed the problem and Xmas dinner for 14 can go on as planned with a working dishwasher.
  • Mfhartman Jan 16, 2011
    I have an optima G 2420 and I don't see any access to the bottom pan via the outside underneath the front panel. I am getting the F70 fault, and the pump keeps going until I unplug the unit. A week ago, I had a stoppage in the drain pipe that the dishwasher/sink was connected to. I was trying to wash dishes before I realized I had a blockage and I got my first F70 fault (this was probably legit). I got the pipes cleared out, but am still getting F70 faults and the intake/drain light blinking. What happens is I run the rinse cycle, which is 15 minutes long, and I can hear the water bring turned on and off in short cycles. It does this at the 13th minute, and oddly never gets past the 13th minute in the program. What is happening is that the dishwasher is filling itself up with water until finally the F70 fault trips and all the water is drained out (almost all of it). I have to open the triple filter in the bottom of the dishwasher and soak up the remaining water. I'm not sure what the intake/drain light is all about, so I checked the waterr pressure and it was over 30 psi, so it shouldn't be an intake problem. I cleaned both the intake filter on the little attachment that con nets to the hot water, and the non-return valve. I did find something lodged in the non-return valve which I was able to remove. However, I'm not getting any results. Any help is appreciated!
  • Tinu
    Tinu May 31, 2015
    check of possible leak at the check valve under the filter screen.
SOURCE:
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
F-21 CODE on maytag 4000 series washer
F21--Long drain
long drain means it is taking to long to drain the water out of the drum.
the pump might be on its way out. running slow faulting.
or it is still is blocked further back.
Nov 14, 2013 | Maytag Washing Machines
F70 fault
Obviously the machine believes the drain cycle is not complete. It is running the drain pump until the level it "sees" is all the way down. Somehow you or your technician will need to get inside the beautiful stainless panels to adjust, clean or replace the drain level sensor...
Dec 27, 2012 | Miele G 2630 SCi Stainless Steel Built-in...
F70 plus not draining completely
check for obstructions in the pump, the hose and the drain.
Sep 25, 2012 | Miele Dishwashers
How to fix leak in miele dish washer g1202 svi has F70 fault and small leak into catch pan
The reason the pump keeps running when F70 fualt appears is that the water leak circuit has tripped which causes the dishwasher controller to empty the dishwasher to avoid flooding of the motor and pump area.
The sources of leaks could be many, to start with hoses and water inlet valve. If you feel you can handle such repairs then go ahead otherwise call a technician.
Make sure the mains power is turned off when you are working with the dishwasher internals.
Aug 10, 2012 | Miele Dishwashers
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
2 year old miele dishwasher runs without being turned on.
hi,
A F70 fault is the float switch in the base of the unit which is activated due to water in the base. you may have used too much detergent or the wrong detergent causing the unit to over sud or you have a genuine water leak. the continous running noise is the drain pump trying to remove any water.
you need to remove the bottom panel, turn the power off and dry up the water with a towel. then run it again and see if you can see a leak.
hope this helps
Jun 03, 2010 | Miele 24 in. G680 Built-in Dishwasher
I have an Miele Optima Series HG03 dishwasher. The dishwasher stops after a minute and the intkae/drain error flashes. I tried everything in the manaual but there is nothing blocking the drain or intake...
hi,
try checking the spigot under the sink as quite often the hole has not been opened up enough and there is a shoulder for food to jam up against causing a blockage. Remove the drain hose and have a look in the hole of the u bend.
If ok remove the filter in the base of the unit and remove the non return valve and make sure the drain pump can turn and there is not anything blocking it.
Dec 28, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Miele Optima G2470SCVi Built-in Dishwasher Logo
27,558 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
