Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Not optimum mode
When i powered the pc on i always get a black screen with a floating box that states: not optimum mode recommended mode 1280 x 1024 60hz. I can't even see anything to interface and attempt to change. There was no problem before and the resolution or hz rate was changed. hello , i have the same problem , i am a dutch guy and i test it on 2 difrence computers ( good working computers ) both computers wen i started him up the title not optimum mode . so its not the computer , the cable from computer to the monitor is new . i think i gif him a bullet . somwone a better id ??
  • pfroeling May 31, 2009
    wen i started him up on savety mode , an i look at the settings they already standing on the right resolution .
    and after 5 min. i get the same problem again .
    wen i want to reset my computer now ,the monitor holt the screen with not optimum mode .
    do you have other sullutions ??
    thanks P Froeling
    Sniper:
  • 80 Answers
This means your computer windows resolution is not display in the correct resolution which your samsung LCD will take.
What you need to do it boot the computer in safe mode. (pressing F8 at start up and select safe mode) This should bring the windows to start up in the generic 800x600 resolution.
Once you are able to see the display in safe mode, go onto the display properties and change the resolution.
* right click on desktop -> properties -> settings
Please rate this if it solves your issue. If you need further assistance please post.
Posted on May 30, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 146 Answers
I have the same monitor with same probelm. I dont know if this is problem with samsungs specific model but the only way to work is the follow.
1. connect your pc to another monitor and set the resolution to 1024x768.
2. set the herz to 60mhz.
3. save the settings .
4. connect your samsung monitor with your pc
You must get clear picture. I dont know why it works 1024x768 with 60hz and not at higher resolutions but this is the only way to work the samsung syncmaster 713bm
Posted on Mar 15, 2013
Screen goes black with a floating sign the says Not Optimum Mode Recommended Mode: 1280x1024 60Hz Took in for repair and work ok there
befor loding windows press F8 then choose vga mode
inside vga mode change the resolution to the recommended mode and restart your pc
then i think it will works
bye
dont forget to rate my solution
Jan 23, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My computer screen has a blue box floating round the black screen, the buttons and mouse dont do anything. There is a message saying 'not optimum mode, recomended mode 1280 x1024 60hz. There is also a...
Basically its telling you to change to the correct resolution. You may have it set too high. If you go into "Safe Mode" you should be able to bring it down. Or if worse comes to worse, uninstall and reinstall your video card. Just make sure to have the drivers available.
Oct 16, 2009 | Computers & Internet
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
Samsung 713N screen goes black
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor shuts down , blank screen with a box floating around saying optimum mode not recommened , recommened mode 1228x1040, then a small box with ? mark inside, ? solution.
Reboot your pc and press F8 to go to the safe mode. You will be able to change the resolution of the screen. And then reboot.
Nov 29, 2008 | Computers & Internet
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
725 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
