Question about Refrigerators
Ice accumulation inside my fridge a little after defrosting it
Ice accumulation inside my fridge even after defrosting it manually how to avoid this and why it happens
    Guru:
  • 462 Answers
IS your refg a frost free? If not you have a manual defrost with cold plates. The only way to defrost these is just as your doing it.
As to what causes the frost buildup; Its a combination of the amount of air that gets into the refg when the door is open, the amount of run time the compressor is made to do, and the humidity in the air around the box. There is no way to avoid it if your going to open the box the air inside will fall out (cold air is heavy) and new warmewr air will be sucked in every time the door is opened.
If its an automatic = frost free type you have something wrong in the defrost circuit. 3 main parts are the
1 defrost timer (or electronic monitor board with electronic sensors),
2The defrost heater
3 the defrost safety limit.
If this helps you decide to repair it yourself well thats another big box or questions. And it is rather lengthy. The tools and how to use them are 1 An ampmeter or volt meter with Ohm scale, a putty knife, a screwdriver streight and phillips, nut driver 1/4" size and 5/16", knowledge of checking a closed circuit and open circuit and how ohm - resistance in relation to volts and watts works.
If you feel better calling someone I suggest this tell who ever it is we talked and you understrand there are 3 main components that allow defrost and you would like him to explain each of them 2 you and show you what they look like. Then next time you have a problem you will have some basic knowledge of where these parts are and what they do and look like. Kind of getting double your moneys worth
If this helps you understand how to proceed with your trouble please rate me as high as you can and thank you for using fixya..
Posted on May 29, 2009
Refrigerator is accumulating ice on the bottom of the freezer unit. Setting is at 0 degrees. There was no spillage.
Does the fridge have an automatic defrost? If so, it may not be working properly. My freezer runs for about 10 months without a problem but eventually ice begins to build up on the bottom. So, I have to perform a manual defrost to remove all the built-up ice inside. Then it will run fine for another 10 months or so when the ice builds up again.
Mar 18, 2017 | Refrigerators
Refrigerator not cooling
The self defrosting mechanism is fubar. Check out the defrost timer and defrost element for proper operation. Chances are that the element is open.
Jun 25, 2016 | Samsung RF266ABRS Bottom Freezer...
Why do I get blobs of water on the inside of my salad drawer in my Fridgemaster. Fridge/Freezer
Leaking Refrigerators
I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil on the average of about every 8 hours so the water that accumulates during defrost has to go somewhere right?
APPLIANCE 911
Dec 15, 2015 | Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Heaps of frost/ice in freezer: Whirlpool wro34uw
You probably need to fully defrost the freezer. Switch it off for at least 24 hours and collect the water as it defrosts. Do not try to scrape it as it can damage the product. The cracking and poping noises are most likely the product trying to auto defrost. It is probably too iced up for Auto defrost to work which is why you need to fully defrost. Good luck.
Feb 20, 2012 | Refrigerators
I own a lg ice beam door cooling fridge for the past five years since recently the fridge is not cooling properly when i open the firdge i see the fan inside the frdige is at standstill pls advice also the...
sounds like u have a deforst problem. if it dont automatical defrost then u have to manually do it then u will have to replace the defrost timer and hope your defrost heaters are still good. ok
Feb 12, 2011 | Refrigerators
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Maytag side by side refrigerator
fridge has timer to adjust for defrosting, but the not working working you to manual defrost the unit to avoid ice formation inside the fridge.
Dec 30, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Refrigerators Logo
183 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
