Question about Samsung CLX 3160fn All-In-One Printer
Won't scan legal documents properly
When I scan a legal document, it comes out as letter size. How can I fix this? The legal document doesn't isn't complete. It cuts off the the top of the document. The paper size comes out legal but without a piece of the document. I don't understand what the paper sizes mean, i.e. A7 A8 B8 etc
  • 489 Answers
Before the scan you will have preview. when you get preview adjust i mean make large the document size
Posted on May 29, 2009
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
Change legal size to letter size
scan it as a document, re-scale it in required size and save then print in required size.
these adjustments are in your word or office programs. if you need to make it to copy, insert your original in the scanner, in paper tray insert your letter paper, select copy and then re-size, this should do it "on the run".
Jul 26, 2010 | Dell 1815dn All-In-One Laser Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
I can't get my printer to scan a legal size document, but have no problem with a letter size.
When you get your control panel for the document, you need to change the configuration document size. In mine, Legal comes right after Letter.
Carl
Jan 01, 2010 | Brother Office Equipment & Supplies
Cannot scan legal size documents. The scan goes through but it will only scan the letter size portion of the document and drops the rest of the text.
You likely need to install the Brother Scanner Resolution Improvement Tool. The description of the download states:
"This tool will expand the maximum scanning resolution capability and allow you to scan legal size documents."
Here is a link for the Windows Vista download
Nov 06, 2009 | Brother MFC 8840D All-In-One Laser Printer
Letter size document scans as legal size document
This is software setting issue. Just check your settings, if a 'default' button is available in the software, press it and then select your required settings. Some softwares dont accept the new settings unless the 'default' is pressed.
S. Mohan
Oct 15, 2009 | HP Office Equipment & Supplies
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
HP Color Laserjet 2840 will not completely scan legal size docs
have you downloaded the scanfix that is own the HP support site?
May 22, 2009 | HP LaserJet 2840 All-In-One Printer
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Jan 07, 2009 | Sharp AR-M550N Copier
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
507 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
