Question about Whirlpool RBD305PR Electric Double Oven
Beeping driving me crazy
I have a double oven by whirlpool. Brand new in new house purchased at auction. Oven never used before. Used it and worked fine but it is beeping and flashing a code. E1 in the screen indicating the upper oven and F5 and F3 in the center of the screen where the time normally displays. Nothing seems to clear this. every 20 minutes or so it goes off with a quick 5 beeps. Pushing the timer cancel button will eventually get the beeping to stop and the time to return but the code will eventually return.
  • zanyzonies Jun 01, 2009
    Wow! Thank you so much, especially for the step by step instructions.
    I really appreciate your time and will get this done asap.
    Thanks again!
  • 6,784 Answers
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Posted on May 29, 2009
  • Michael Masters
    Michael Masters May 29, 2009
    The numbers are suppose to be letters. sorry for the technical difficult.
  • Michael Masters
    1. If door latched:
      proceed to step C.
    4. Re-apply power.
      proceed to step C.
Rbd305pdb14 error code F5
Dear Valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Dear Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool RBD305PD Electric Double Oven
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
Kenmore double wall oven keeps beeping
I have a whirlpool stove and when I try to clean it after awhile it starts beeping and comes accross with E1 & F5 the oven when its to clean dosen't seem like its locking. How can I fix this problem. Ive missplaced my book somewhere and can't seem to find it. My timer and clock is digital. Can you help me solve this problem? Thanks!
Aug 22, 2009 | Kenmore Ovens
Dislpay is blank but oven works
HI, you will need to replace this faulty ECC. the chip set that is soldered on this board is damaged as well as the led display. replacing the Electronic Clock Control will fix this issue.
the control board is fine and this explains why the oven is still functional. its the ECC that is faulty.
Click here to purchase your new ECC online.
May 25, 2009 | Whirlpool RBD305PD Electric Double Oven
Jen Air double oven only beeps when you make any selection.
can you look real close at the display, its possibel that the display has "dimmed" and unit is actually working, but just cannot read the display as to what its actually doing, in this case replaccingthe display board will correct your problem
Mar 08, 2009 | Jenn-Air JJW8230D Electric Double Oven
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Pruneau
Aug 18, 2007 | Thermador SMW272 Electric Double Oven
Whirlpool RBD305PR Electric Double Oven Logo
275 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
