Question about Sebo Automatic X1 Bagged Upright Vacuum
Sebo X1 motor bearings
I'm on the hunt for some motor bearings for a Sebo X1.
Does anyone have a source for bearings, or can advise me of how to work out which ones I need?
  • sc117 Jun 02, 2009
    Thanks for your help with that, you've inspired me to pull this apart and see where I get to - it owes me nothing after all, if it works it's a bonus, else I'll just buy another motor.
    Now my first problem which is fairly simple, this particular motor doesn't have much to grab onto to stop the shaft spinning when trying to undo the nut on the fan - which I'm assuming will allow me to remove that end of the motor. Any tips?
    I could grab onto the end used to drive the belt, I just don't want to shear it off.
I have the sebo automatic X1.1 and out the blue it starting making a very change noise and a burning smell, i have taken the brush out and checked it wasn't blocked or jammed so i am now worried the problem is with the motor, oh forget to say the machine never turned off automatically it just kept going till i turned it off....can you please give me any advise as the machine is only 3 yrs old...Thank you
Posted on Apr 24, 2011
  • 15 Answers
For me (after having done this game in a variety of ways, in a variety of AC motors of all kinds), you just have to bite the bullet, and pull the motor apart to find out, UNLESS you can get lucky enough as you suggested, and find a source of information for the SPECIFIC bearings for that SPECIFIC motor.
If you go the old-fashioned route of pulling the motor down, and checking the end-plates for the type of bearing (sealed, non-sealed, bushing, roller, you name it), you are already in so far, you might as well tap out the bearings. How? Why...just start tapping.
Be easy and gentle! Don't warp the rotor shaft! (In fact, clean the shaft very nicely BEFORE attempting to pull the bearings, some emery cloth and WD-40 works nicely, etc.)
After you have the bearings out (most likely sealed, most likely roller bearing, or brass sleeve bushing), you then have the fun of:
1. Measuring them up, and then internet buying.
(Measure "Inside Diameter/Shaft" and "Outside Diameter", along with "Length)
2. Going local. Sometimes, lawnmower shops, and even Auto Parts stores have these.
3. Going "Old School". Yes, if you have a really bored friend at a machine shop, they can make awesome parts on the spot. Even sleeve bushings you can't find, or can't wait on. Don't rush those guys! They are solid GOLD!
You then do your dance, and put it back together.
Note: When you tear a motor down, remember some things.
1. Mark both end caps, so they go back on to the same ends they came off.
2. Sometimes, you get DC motors. This STILL applies to them, with the exception they have commutators/brushes. Believe it or not, you can run a 40 year old drill by using bread twisties to hold brushes in/on. These things ARE forgiving.
3. Caution & Patience. If you can't ease it off.....NEVER force it off.
4. If it came off easy, don't force it back on hard!
5. Just because a specific "size & horse" motor went in running 110v, does NOT mean you can't put a completely different motor size in. You CAN make miracles, with all of the above in mind.
Well, that and "Luck"........
6. Just because "specific" bearings were in there, doesn't mean you can't modify those end-caps to take different, or better bearings. It ALL depends on what YOU want to do, and how much TIME you want to take. You CAN make sealed bearings into "oilers", and vice versa, simply by reworking within what you can.
Posted on May 30, 2009
Sebo vac grinding noise and burnt smell
Take it to your local vac shop for assessment. Sounds like a bad motor. If they are not a Sebo dealer, make sure they know that a X1 motor is not the same as an X4 motor. It should cost around $200 for the total repair . A new X4 is $799 so the repair is usually a good idea.
Jun 16, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Hi. I have a Sebo X1 about 12 years old. Last time I used it there was an unpleasant smell in the room but didn't seem to be coming from the Sebo. However I am now trying to use it and it doesn't work. The...
The unpleasant smell could have been the lifetime belt finally giving up. Also happened on our 13 year SEBO X1 Automatic due to my error of vacuuming up a rug with long loose strands! If you are good with a screwdriver, you can replace the drive belt easily enough - go onto You Tube - there is an excellent UK video showing how to replace the drive belt on the SEBO. There are two belts, but you will know which one has to be replaced if you remove the screws on the underside of the main floor head. Before you do anything, kneel on the floor beside the SEBO and press the main release button on the bottom of the front bin area just above the floor head. It may need brute force but when pressed, put on knee on the floor head gently and pull the bin upwards to release from the body of the SEBO. This unlocks the main floor head from the bin, making it easier to look at the floor head. See video: http://www.youtube.com/watch?v=AOPphVcZHYA
Sep 14, 2013 | Sebo Vacuums
Our Sebo Automatic x1 will now only pick up with nozzle. Hight adjustment doesn't seem to operate and no green lights display. No blockage found, roller works okay. Help! Wife becoming v. angry.
The belt on the motor shaft is probably slipping off. I have the same problem and that's what I saw when I opened the vacuum. I keep putting the belt back, but it slips off again. The belts aren't supposed to stretch. I am going to call Sebo and take mine to an authorized service place to make sure that it is just a stretched belt.
Jul 10, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuum motor hunting (varying speeds) eventually stopping
Hi Colin. This does not sound good. Sebo's are great machines. I think the motor brushes are going. If so, they can be repaired and the Sebo is worth fixing. Let me know please. Chris
Feb 09, 2011 | Sebo Vacuums
Sebo automatic X1. After switching on the motor
As sure as possible without actually seeing your machine, the carbon brushes on the motor are worn out. They are quite easy to replace (and not expensive). If you need help with doing the job, just post a reply here and I'll guide you as best I can. If you choose to have a professional do it for you, it should take no more than half an hour's labour.
I hope this has been helpful - please remember to score me! Good luck!
Feb 10, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Need Sebo x-1 parts
Hi
contact them direct they will help you out
SEBO America, LLC
7472 S. Tucson Way, Suite 190
Centennial, CO 80112
or look here
http://www.sebo-vacuums.com/frameset.htm?dir=Support
Please leave feedback for me
Thanks
Rob
Feb 12, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X1 vacuum not working
The X1 has a servo motor with gear box, this is what adjusts for height. Either something has jammed it, or
it has gone bad. You would probably be looking at a $80 to $100 repair, that is if the servo is bad. There also is a computer controller circuit board which could be the problem.
Mar 08, 2008 | Vacuums
Sebo Automatic X1 Bagged Upright Vacuum Logo
425 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
