Question about Gaggia Titanium Espresso Machine
Fill Water Tank But Water Tank is Full
My new Gaggia Titanium espresso is one that has not gotten much use. My screen indicates "Fill Water Tank" but my water tank is full. Any advice?! It worked well the few times that I used it but now, no more espresso! Thank you i have the same problem fill the watertank but the water full
Check the little black rectangular box which is in a plastic channel at the back. To work properly, the rectangular box, with the narrower end facing downwards, needs to be floating at the top of that channel. Apparently it's a magnet which signals the circuitry that the water tank is full. Make sure it's floating to the cap of the channel. If not, you can get a replacement one from Gaggia.
Posted on Jun 02, 2009
    President:
  • 1,618 Answers
Try this, remove tank, turn off machine, open steam/hot water valve, insert full tank and turn machine on, press button for hot water.
Posted on May 30, 2009
The magnet trick worked perfectly!I found a 3mm thick magnet to tape to the rear of the machine between it and the reservoir. The internal magnet seemed past its shelf life, thanks.
Posted on Dec 10, 2011
2 Suggested Answers
SOURCE: Fill Water Tank But Water Tank is Full
As suggested previously by pierre235, the solution is really simple: make sure that the float in the tank really does float when water is full. Here it is exactly how...>>...fill the tank slowly (as it is still unattached to the machine) ensuring that the float does float and then slowly put/attach the tank back with the machine - keep checking the display for status. Then, if it's OK, fill the rest of the tank until it's full. Then restart the machine - voi la .. all works.
Posted on Mar 25, 2008
Gaggia syncrony compact digital expresso maker says fill water tank but water tank is full
Check the float in the tank that indicates the water level to the sensor. They often fail to float, solution is to either replace the tank or jam something plastic under the float to lift it to the top of its slot.
Jan 01, 2016 | Gaggia Syncrony Compact Digital Espresso...
Water tank is full on my gaggia plaitium swing up but it is asking me to fill water tank
Then the float or sensor is not ingaging to show that there is water to that level so i would try to dump some water down a few times and force the float back up or try to reach it with your hand and move it very easily up and down then try to fill it and i bet it works fine. Thanks
Sep 03, 2012 | Gaggia 102498 Platinum Swing Automatic...
Gaggia Titanium SUP027 YDR Syptom: Displays Fill water tank even though the water tank is full and freezes the operation of the coffee machine
Be sure to check the float in your water tank. It looks like this: http://www.cerinicoffee.com/item.asp?PID=1318
If the float is not floating then you need to replace it.
Jun 05, 2011 | Gaggia Titanium Espresso Machine
The float in the water tank keeps sinking resulting in fill water tank even when full
Sounds like there is a hole in the float, either replace the float or the tank.
Aug 25, 2010 | Gaggia Titanium Espresso Machine
My Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Nov 10, 2009 | Gaggia Titanium Espresso Machine
Fill water tank message appear even when tank is full
Check the float in the water tank,it can stick or leak water and sink to the bottom.
Jul 17, 2009 | Gaggia Titanium Espresso Machine
Espresso gaggia titanium. Water Tank leaking
The o-ring on the bottom of the water tank is either missing or not seated properly.
May 10, 2009 | Gaggia Titanium Espresso Machine
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
1,079 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
