Question about Panasonic SC-HT730 System
No power to main unit
The light on the subwoofer comes on, but the DVD unit has no power
  • USMC0331 Dec 22, 2007
    Same thing! I have everything set up right, Power light on the subwoofer comes on, but NOTHING from the receiver??
  • J-Daddy Feb 24, 2008
    My problem is very similar. I have the main unit plugged in along with the subwoofer. The power light remains on. When I hit the power button to turn it off, go to the main unit to press open/close on the DVD player, or hit input selections on the main unit, the light on the subwoofer and main unit goes off for about 2 seconds then turns back on. I have to unplug the unit in order to turn off both the subwoofer and the main unit.
    Everything is plugged up properly but I'm not gettin anywhere with setting up the home theatre system. Not sure if it's a fuse or not but certainly a power issue. Any help and/or suggestions anyone can give would be greatly appreciated.
  • 4 Answers
This is easy       either bad cord or bad internal power supply.
Posted on Oct 24, 2007
  • CHRISTOPHER MARSH Oct 24, 2007
    if im correct the sub has its own power supply
Onkyo dr s2.0 DVD receiver has subwoofer output but no other speakers have sound. I have experience with electronics. Is there fuses for the preamps and power outputs separate from the main in ?
Hello Todd, I would not suggest trying to repair this unit yourself. I suggest an authorized service but it might be difficult getting parts. Thank you, Onkyo USA
Oct 03, 2016 | Onkyo Audio Players & Recorders
I GOT A YAMAHA SUBWOOFER SW 315 FROM USA WITH 120V RATING. BY FAULT I PLUGGED IT INTO 220V . NOW THE POWER LIGHT IS COMING BUT NO SOUND IS COMING FROM SUB. HOW CAN STANDBY LIGHT COME IF I BLOWN THE...
chances are that you have blown part of the circuitry insode the power supply. The power supply is recieving power, hence the standby light but not giving any actual output. If you are competant with electronics and can work on the power supply safely, take a part the power supply and look for any components which look to have scorching around them and test for operation. Obviously make sure that the units is UNPLUGGED from the mains supply before attepting this.
May 02, 2011 | Yamaha YST-SW315 Subwoofer
LED lights dim on HT720
Check the subwoofer for a blown fuse. I hope this helps. ~ Bruce :)
Aug 31, 2009 | Audio Players & Recorders
HS 500 noise from subwoofer
Well as I see from the owner manual for this device the sub is active one and my opinion is that electric is your problem.The power of the sub and main unit must be on the same phase otherwise you'll hear brrrrr or frequency of your main unit power supply on the sub.Thats why sound changes when you open or close the door.Take one power distribution cord (get power for bought devices from the same place) and connect main unit and the sub on it and then try.I hope that this will help you
Mar 04, 2008 | Audio Players & Recorders
Power issues: will not turn off or function
Unplug all of the speakers and power on.Its possible that one of the speakers is causing the protection circuit to activate.If powered on and subwoofer works start reconnecting one speaker at a time( after powered off) and retest each time.One Speaker may be bad.Its also possible the output ic is failing under a speaker load.There are no fuses related to this issue.If its not a speaker problem then the subwoofer will need to be serviced.
Feb 24, 2008 | Panasonic SC-HT730 System
Can't get sound from the wireless subwoofer
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Jul 25, 2007 | Panasonic SC-PT1050 System
SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Oct 21, 2006 | JVC TH-M505 System
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
Panasonic SC-HT730 System Logo
115 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
