Question about HP Pavilion dv9000z Notebook
Blue screen - Damping mem
Actually is a very old HP Pavilion ze5400 laptop, is damping memory, please help!
    President:
  • 2,004 Answers
System restore to factory default is the solution. Remember to backup your documents.
rate this.
Posted on May 29, 2009
I have the HP Pavilion a1330n computer, I just installed 4G of memory (4 X1G) to replace my previous 1G (2 X 512). The memory specs are correct but every morning the computer has a black screen and I have...
NO OS stated, Blues screens you mean the BSOD with the halt? statement on screen? i bet yes. (with words on blue screen)
words matter.....
Bought new memory or old?
no, (to supposed) yes, to , back to beginning done wrong or luck bad.
so put back the old RAM, does that work.?
or use just 1 stick of old ram. ? 1 by 1.
then repeat, new ram 1by1,
see? one stick is bad, if it all ran perfectly before you touched ram.
buying RAM for such and old PC is not easy.
step1:
first ASK HP, you asked now at yahoo, why here, and not HP>?
but HP long long ago retired the A series.
per HP pages. here
https://support.hp.com/us-en/retired-products
personally I do go the used PC store and buy $20 PC vastly newer.
sure would, but lets follow the rules for yours, step by step
step 2, (1 was hp , no support)
next is to lean what Memory was uses and what the processor spec is on the same,
the mobo is 2005 era. (as old as) 12 years ago...
its not Intel, its Athlon 64 (S) 3800+ 2.4 GHz
if it was intel , the intel chip drives the memory with its MMC
its not.
ASUS made this mobo by HP contract.A8AE-LE
hp name is: AmberineM-GL6E
max mem
4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
PC-3200 MB/sec , speed ( not slower !) faster ok.
184 pin, DDR SDRAM
Dual-channel memory architecture
4 x 184-pin DDR DIMM sockets support unbuffered non-ECC 4 GB 400/300 MHZ DDR memory modules
page 7 is sparse in your manual.
https://www.manualslib.com/manual/721818/Asus-A8ae-Le.html?page=7#manual
the Athalon 64 has an ON DIE mmc, memory controller
this sets the base limits of all possible memory.
the memory speed is not by FSB, speeds
simpler terms, the memory is always running at a set fraction of the CPU speed
this chip has the advantage for running , cleaner DDR signals.
that other FSB designs.
what that means , to the user more memory choices.
I see this maker selling memory , a top maker,
http://www.crucial.com/usa/en/compatible-upgrade-for/HP-Compaq/pavilion-a1330n-series
test the sticks all 1 by 1,,, one good way to test it is run fast games.
DDR stick density rules and numbers and types of memory pre stick and pre side can cause problems on old processors.
I could not find the Athalon 64 rules on this, AMD can tell you at there site but im too lazy to look it up..
best is to let Crucial or Kingston guy you , here. for SURE>
Jul 13, 2017 | HP Pavilion a1330n (EL466AA) PC Desktop
Lights come on, fan comes on, no monitor, no HD activity, no bios beeps, all hardware removed from the under compartment. Still nothing.
Boot laptop with no memory installed should give seris of beeps to clear memory,next remove battery install mem if it boots ok battery hanging up laptop if not plug in mem one at a time to see if one is bad.
Jan 11, 2011 | HP 417035-001 - HP Pavilion dv2000 Series...
Bought 1G ram from local computer store. It runs for about 5 minutes then i get a blue screen error and reboot. returned to store for a different mem stick...same issue. went to Crucial, found the...
Did you remove the "old" RAM, or did you add the "new" RAM to the old RAM?
Try using your computer with ONLY the "new" RAM installed.
Try using your computer with ONLY the "old" RAM installed.
Try using your computer with the "new" RAM in the 1st slot, and the "old" RAM in the 2nd slot.
Try using your computer with the "old" RAM in the 1st slot, and the "new" RAM in the 2nd slot.
Aug 27, 2010 | HP Pavilion ZV5220US (PF143UA) PC Notebook
Factory suspension settings
Spring preload FR
To increase the spring preload and
thereby harden the suspension, turn
the adjusting bolt on each fork leg in direction
a. To decrease the spring preload
and thereby soften the
suspension, turn the adjusting bolt on
each fork leg in direction b
NOTE: _
Align the appropriate groove on the adjusting
mechanism with the top of the
front fork cap bolt.
_
CI-10E
Rebound damping force
To increase the rebound damping
force and thereby harden the rebound
damping, turn the adjusting screw on
each fork leg in direction a. To decrease
the rebound damping force and
thereby soften the rebound damping,
turn the adjusting screw on each fork
leg in direction b.
CI-02E
Compression damping force
To increase the compression damping
force and thereby harden the compression
on each fork leg in direction a. To decrease
the compression damping force
and thereby soften the compression
each fork leg in direction b.
CI-02E
1. Current setting
2. Front fork cap bolt
Setting
Minimum (soft) 8
Standard 6
Maximum (hard) 1
1. Rebound damping force adjusting screw
Minimum (soft) 26 clicks in direction b*
Standard 13 clicks in direction b*
Maximum (hard) 1 click in direction b*
* With the adjusting screw fully turned in direction a
1. Compression damping force adjusting screw
Minimum (soft) 20 clicks in direction b*
_
Although the total number of clicks of a
damping force adjusting mechanism
may not exactly match the above specifications
due to small differences in
production, the actual number of clicks
always represents the entire adjusting
range. To obtain a precise adjustment,
it would be advisable to check the number
of clicks of each damping force adjusting
mechanism and to modify the
specifications as necessary
CI-10E
Rebound damping force RR
damping, turn the adjusting screw in direction
a. To decrease the rebound
damping force and thereby soften the
rebound damping, turn the adjusting
screw in direction b.
CI-14E
in direction a. To decrease the compression
soften the compression damping, turn
the adjusting screw in direction b.
CI-14E
Setting
Minimum (soft) 1
Standard 4
Maximum (hard) 9
Whole process where need to turn toward "a" means clockwise and "b" counterclockwise. From Yamaha service manual. Hope this is good enough info to help you out. Good?
May 03, 2010 | 2002 Yamaha YZF-R1
User manual wanted
Sir, you can get the service manual at http://online.manualspace.com/notebook-computers-free-ebooks/hp-notebook-service-manuals/4427/hp-pavilion-ze5400-notebook-pc-service-manual-230.html
Sir, you can get the Startup User guide at http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bph08615/bph08615.pdf
Sir, The service manual is just an additional information as I thought you can need it, Thank you Sir.
Sep 24, 2009 | HP Pavilion Notebook
Prove for "Hp Pavilion dv8216tx has 512mb graphic memory"
http://www.laptopviews.com/hp-laptops/hp-pavilion-dv8216tx-laptop-pc/ shows NVIDIA GeForce Go 7400 dedicated Video Graphics chipset with 256MB Turbocache Memory offering 1280 x 800 pixels screen resolution
Jun 04, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Sd driver not working
try to insert the sd card slowly and watch the blue light if starts to blink that means it is reading your memory card then that must be the depth u can insert your memory card for the reader to work. hope this is helpful
May 12, 2009 | HP Pavilion dv1000 Notebook
After blue screen restart the computer always
sounds that you have a virus problem so quickly get an updated antivirus from listed below esp
bitdefender
webroot
kasperkey
avg 8
nod32 etc
Mar 10, 2009 | HP Pavilion dv1000 Notebook
I have a HP Paviliandv600 probloms....
all you need to do is install whatever os you prefer.
blue screen usually happens with insufficient ram(mem)or incompatability issues(conflicts)sometimes can indicate bad sectors on hd...when all else is checked and faults still occur its usually hd bad sectors which without software to detect this your system gives you no indication of what the fault may be and just keeps crashing.
I have hdd recover software if you send ur email I can post it to you
Jan 15, 2009 | HP Pavilion DV6500Z Notebook
LAPTOP HP PAVILION DV2000 problem
Hello!
That beeps indicated that there is a problem in the video Graphics adapter and in the memory.
try remove and clean the memory and then fix it back, im sure that would resolve your problems. however if this not solve then your should replace the memory.
If affraid to do so, then maybe let the repairman do it for you.
fixya!
best regards, melnavz
Feb 29, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
