Question about Hotpoint HSS25GFP Side by Side Refrigerator
I have hss25gfp side by side the freezer stopped freezing and it very hot on the middle divider. I took off the bottom on the back and it was caked with a bunch of lint. I cleaned it off. But noticed the fan, I guess on the coils isn't turning on. Not sure if that takes time to turn on. But could it be that fan is no longer working?
  • sanctyfied1 May 29, 2009
    Thank you, When I cleaned out all that lint built up. I plugged it back in That same fan was not moving at all. I span it with a screw driver cause I noticed it was trying to turn but wouldn't I got it to spin and spray a bit of WD-40 on it. It seems to be cooling down now.
    So what you said here has got to be the problem. Thank you for the fast reply. I will continue to look at it. To see if I do need a new fan. But so far it's looking good. That lint was very bad in there.
    Thank you so much again for your help.
  • 585 Answers
If the compressor is running the condenser fan should be too. If the fan does not run the compressor will overheat and stop. If you cool the underside with a small box fan and the chill returns to the box, replace the condenser fan.
Posted on May 29, 2009
My refrigerator is hot! To be clear, the frig is cooling, but the divider between the frig and freezer is so hot that it almost burned my arm! The lower part of the freezer is defrosting as well.
Your condenser grill under your frigerator is dirty and not able to get rid of the heat. If you take off the front grill and the back panel and vacuum it out or better yet, blow it out with an air compressor, it should solve your problem.
Also make sure that the condenser fan is operating because that would also cause the same symptoms.
Aug 07, 2011 | Hotpoint HSS25GFP Side by Side...
Ice build up in the bottom of the freezer
fridge freezing in the bottom of compartment? freezer not frosting either? please solve this problem
Oct 09, 2010 | Hotpoint HSS25GFP Side by Side...
I have water comming out of the freezer at times and a pool below the bottom shelf.
You drain has frozen up probably because of a clog. Take the bottom door out and right at the rear bottom of the freezer back in the middle you sill see a drain. When the freezer goes in deefrost the frost will melt on the evaporaterr lines and must go down under the freezer yours does not and when the freezer comes on that water freezes. next time it defrost it heats that ice and the melted water come out the front of he door. clean that drain.
Jun 06, 2010 | Hotpoint HSS25GFP Side by Side...
My is SxS fridge is warm on top & freezing on bottom- both sides
there is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
I have a side by side refrigerator/freezer & the top sections of both will not get cold or freeze ice. However, the bottom (about 1/3) is getting cold. Any advice?
sounds like either a defrost problem or freezer fan motor problem. open freezer door, hold in light switch and listen for sound of fan motor. if fan is ok. check for frost build up on back wall of freezer. post what you find out.
Jan 05, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer will not keep foods frozen fridge will not keeep temp.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
Jul 11, 2009 | Hotpoint HSS25GFP Side by Side...
Water drips from bottom of fridge. It happens
look in the bottom of the inside of the freezer, you probably will see ice buildup.You have to clear the drain which is stopped up at the bottom of the panel that covers the freezer evaporator.Every 8 hours the drain receives water from the auto defrost and needs to go in the drain, if drain is stopped up it freezes and eventually runs out the front
Mar 25, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint HSS25GFP Side by Side Refrigerator Logo
210 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
