Question about Whirlpool Dryers
How do you light pilot light?
Dryer was not heating last night and today, after taking off the front of the dryer, I noticed that the pilot light is off.
  • 864 Answers
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
Posted on May 29, 2009
No heat, I have verified 220 service both breakers are not tripping, 220 plug gets current. No obstruction in vent also ran without vent pipe attached I did notice last night sensor dyer level light...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 03, 2011 | Maytag MDE9700AYM Electric Dryer
Pilot out dryer does not dry.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 22, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
Whirlpool gas dryer, no heat and no flame
check you thermal fuse with an ohm meter if selected only air and close the door and no air comes from the rear where the vent hooks up clear the vent blower housing then check the thermal fuses on the units exaust assy inside the unit
Aug 19, 2009 | Dryers
Maytag neptune dryer not heating up to dry clothes.
On my dryer the igniter is rt behind the front panel. Take off the dooe and a few screws and pull it off. If the igniter lights at all it is good. Try also checking the entire discharge vent hose as sometimes it gets clogged way dn line and you might not notice it. Try squeezing it all the way dn.
Mar 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Finding pilot light for a Kenmore dryer model # 97581110
theres no standing pilot in dryers is it on a heat setting or air dry .then look thru that small hole while in aheat setting on the timer. when you press the start button you will hear two clicks the see the glow ignitor glowing.if its not glowingyou would need to check voltage at the ignitor if no voltage problem will be thermol cut out fuse
Jan 01, 2009 | Dryers
How to light the pilot?
If this is an electric dryer, it doesn't have a pilot either. If this is a gas dryer it will have an electric pilot. but then if it were a gas dryer, it would have a removable lower front panel for servicing the burner. So you must have an electric dryer. if the dryer runs but does not heat, the electric element is most likely at fault. If you really were looking for a pilot light on an electric dryer, I must recommend that you call a reputable appliance service regarding repairs so as to not jeopardize your safety.
Aug 31, 2008 | Kenmore 84052 Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 22, 2007 | Whirlpool LER4634J Electric Dryer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Dryers Logo
315 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
