Question about Nikon D60 Digital Camera
Highlight problem on D60
When I play back the taken pictures, areas of light seem to be flashing. How can I turn this off?
  • penocooks May 31, 2009
    hey thank you...what do I do in the menu bar? Where do I go?
  • 464 Answers
Reset your camera to factory settings. that will do.but if you dont want to lose all the settings then you should scroll the options in the menu bar and you should turn it off. thanks for using fixya!. please dont forget to rate my solution.
Posted on May 30, 2009
My D60 only when I use the flash I get an error message job nr
Job NR is usually associated with the camera's processing time during very slow shutters. If you wait long enough it will show you the image you've taken but because the shutter is very slow, the image will be blurry and unrecognizable. On manual mode or Shutter speed priority change your shutter speed to at least .125 of a second. That should fix the problem.
Apr 16, 2013 | Nikon D60 Digital Camera
I have a Nikon D60 camera. Switched it on today and there is no image in the LED display when I try to take a picture, the screen is black.
That's normal for the D60. It works the same way SLRs have worked for half a century: you view and compose through the optical viewfinder, then snap the picture. The D60 lacks the Live View feature of more recent dSLRs; the LCD (not LED) display on the back is for menus, settings, and reviewing pictures after you've taken them. It is not for composing and framing your pictures.
Apr 01, 2010 | Nikon D60 Digital Camera
On the viewfinder, parts of the picture flashes black.
It sounds like you have the display set to show image "highlights", this is a mode that shows parts of the picture that has become over exposed and have no detail contained within that area, in other words the parts of the photo that are pure white.
The camera Highlights as one of several different modes that can be flicked through after looking at a photo you have taken. hope this helps  Ian
Sep 07, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Nikon d60 won't play back pictures
Sounds like your computer or the software program you're using to download your pics is set to automatically erase the card after the download.
Aug 14, 2009 | Nikon D60 Digital Camera
When ever there is a picture taken there is a flicker when i view the picture in my camera it happens only on the bright spots ...ehy is it
It's normal.
The Nikon dSLRs have various LCD display modes, and one of them is called "highlight clipping warning display". Basically, when you set your LCD display to "highlight clipping warning display"(it's the mode right before the "histogram display"), it blinks white/black wherever your picture has blown highlights (i.e. where your picture is overexposed)
A histogram display is very helpful in telling whether you've got the exposure right, but to it isn't adequate by itself. With digital cameras, it's very important not to blow-out the highlights in a picture (they're similar to color positive film in that respect), since once you hit the maximum brightness, the image just saturates, and any highlight detail will be lost. A histogram display does a pretty good job of telling you how the image as a whole is doing, but what if there are just a few critical areas that you're worried about for the highlights? If only a small percentage of the total frame is involved, it won't account for many pixels. That means any peak at the "white" end of the histogram graph would be pretty small, and easy to miss (or just plain invisible). What to do? The folks at Nikon recognized this problem some time ago, and so have provided another special display mode on the D60 (as on most of their dSLRs) that they simply call "highlights," accessible via the Playback settings menu, under "Display Mode." This mode blinks any highlights that are saturated in any of the color channels. It does this by taking the nearly-white areas on the LCD and toggling them between white and black.
Aug 03, 2009 | Nikon D60 Digital Camera
When I play back the pictures, there is white light flashing
You're seeing blown-out highlights. Take a look at this for more details.
Jun 14, 2009 | Nikon D60 Digital Camera
Powershot A540 flash does not work
Hi. I had the same problem. I called Canon and they told me to reset the camera, and it worked. The camera is back to normal. To reset, hit the "menu" button and then scroll over to the tab with the tools icon. Scroll down until you see "Reset All". Hit "set" then highlight OK and hit "set" again. It will say "busy" if it was reset correctly. I had to do it twice for it to work, but it seems to be working fine now. Hope that helps.
Jun 07, 2009 | Canon PowerShot A540 Digital Camera
Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
May 29, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Nikon D40 - Flashing black on the light/white areas of inside & outside pics
It sounds as if you have changed the viewing setting so that the camera highlights over-exposed/highlight areas of the image.
While playing back images, press the multi-selector (4 way cursor) up or down to cycle through the various options.
This should be explained on page 51 of the cameras manual.
Hope this helps.
Matt.
Mar 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon D60 Digital Camera Logo
319 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
