Question about Panasonic (TH-50PZ700U) Television
There is a black square in the upper right corner of tv
The square is on every channel, tv dvd dvr
Thanks to gary for solution as I had this problem on my old Hannspree XV tv. Went into Menu, then Calibration and there is option to turn off PIP as above...dont know how it wad turned on...
Posted on Apr 25, 2013
  • 110 Answers
This my be your PIP ( picture in picture). check yor menu to see if it is on.
Posted on May 29, 2009
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
My projection hitachi tv has a blank square showing up on the upper left hand corner. it shows up on all tv channels, but is fine when using DVD. What is the problem?
Sounds like you have Picture in Picture enabled. It doesn't show when viewing DVD because the DVD is the PIP. Just turn PIP off, there should be a button for it on the remote.
Nov 24, 2009 | Hitachi 51F500 51" Rear Projection...
Dlp tv has smattering of white (and just a few black) squares in upper right hand corner. Thick at corner then thining as spreads. Covers1/4 of picture. The rest of the picture is perfect.
You have a bad DMD board. It is easily replaced but not easily aligned. I would suggest having a technician look at the TV. The DMD board is the board with the million little mirros on it. The white squares indicate a few mirrors sticking in the on position reflecting the light from the lamp constantly. The black are just the opposite reflecting no light at all.
Oct 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
Apr 29, 2009 | Sharp Aquos LC-32D40U Television
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
I can only get snow on my tv screen
Does your controller turn the tv on and off?
Dec 16, 2008 | Microsoft Xbox 360 Console
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Panasonic (TH-50PZ700U) Television Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
