Question about HP Color LaserJet 2600n Printer
ETB ASSEMBLY REPLACING ETB ASSEMBLY, HOW TO REMOVE THE OLD ONE
Probably www.laserpros.com/pdf/HP 2600-2605 fuser-etb.pdf will help...
Posted on Nov 20, 2007
How to install transferbelt
  1. Remove or slightly pull out Tray 2 (RM1-1916-000CN).
  2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
    assembly.
  3. Open the front door
  4. Remove the right cover (RM1-1858-000CN), carefully twisting the front edges of the side covers
    outward to remove.
    NOTE :
    To make the removal of the right cover assembly easier, release the tab on the inside of the cover.
  5. Remove the left cover.
  6. Squeeze the white link lever on the left side.
  7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
  8. Close the ETB.
  9. Remove the small black cable cover (RC1-5147-000CN) on the left side of the printer by carefully snapping it out of place.
  10. Remove one (1) grounding screw from the ETB harness.
  11. Pull out the white wire holder by pushing it up.
  12. Pull out the ETB connector.
  13. Remove one (1) screw from each hinge cam on both sides.
  14. Using needle-nose pliers, remove the hinge left cam (RC1-4249-000CN) and the right hinge cam (RC1-5311-000CN).
Remove the ETB. Use the following procedure to replace the ETB.
  1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left side.
  2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE :
When replacing the right cover, align the tabs on the upper edge of the right cover and lower edge of the face-down cover with their respective slots.
Nov 19, 2013 | HP Color LaserJet 2600n Printer
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
Jul 26, 2012 | HP Color LaserJet 5550hdn Printer
Error 59.90
ETB motor start up error>Check ETB inter mediate connector J36 &J38, remove & reconnect them.>Check J1111 connector on DC controller remove & reconnect it.>Check ETB motor.>Replace ETB>Replace DC controller(Snap shot)
Dec 24, 2011 | HP LaserJet 5550DN Printer
Can't remove toner cartru]idges after replacing ETB
The ETB isn't seated correctly.
Remove it and make sure that the two black plastic connectors at the printer bottom are both in the down position before you slide the ETB in.
Close and open the front cover and you should be able to watch the toner cartridges open and close.
Feb 24, 2011 | HP Color LaserJet 2600n Printer
How can I solve the proble of 59 FO error code appear in the HP laserjet 3800 printer
The error says that "The transfer rollers in the ETB are not
engaged."
If replacing the ETB(electronic transfer belt) doesn't fix the problem, your printer is going to need a technician. Problem could be poor seating of the cables on the ETB motor or the 'transfer-roller separation solenoid or the DC Controller.
It could be a bad ETB motor or solenoid or DC Controller or high voltage power supply.
This isn't something that is going to be fixed by email.
I hope you have a service contract for your printer.
Feb 18, 2011 | HP LaserJet 3800dn Printer
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
Jan 13, 2011 | HP Color LaserJet 2600n Printer
How do you install a transfer kit to 4700 dtn printer?
Replacing the ETB (transfer Kit)
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
Jan 13, 2011 | HP LaserJet 4700 Printer
How to exchange the ETB unit (belt) on a HP Colorlaserjet 2600n?
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here...
ETB removal and replacement
Use the following procedure to remove the ETB (RM1–1881–000CN).
1. Remove or slightly pull out Tray 2 (RM1–1916–000CN).
assembly.
3. Open the front door.
4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers
outward to remove.
NOTE : To make the removal of the right cover assembly easier, release the tab on the
8. Close the ETB.
9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by
14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge
cam (RC1–5311–000CN).
15. Remove the ETB.
side.
NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover
May 23, 2010 | HP Color LaserJet 2600n Printer
No charge on the ETB and or paper, Causing paper fold and jams. Any ideas o brainy ones?
No idea what no charge on ETB/ Transfer kit or paper means?
As far as the jamming with folds? means there is an obstruction in the paper path. Check for labels, bits and pieces of paper etc. Check the paper pickup assembly "paper guide" it often pops out on one side when the paper tray is pulled out roughly by that troubled angry employee. Old fuser that has been reset instead of replaced can do that also. Also check feed rollers they shoud not be slick if they are you will get frequent paper jams.
Sep 04, 2009 | HP LaserJet 5550 Printer
How to replace the transfer belt Electrostatic Transfer Belt
That depends what kind of printer you're dealing with. In general, you should just open a front cover. Then release the ETB from the rest of the machine. Look for two blue handles to release the ETB. Replace the ETB and make sure the printer detects the new ETB. If the printer don't detects the new ETB, try to restart the printer or reset the ETB-counter in -Configue device--->resets----->reset supplies----->NEW ETB.
Jul 29, 2009 | HP Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
334 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
