Question about Gestetner Copier
How do I send an immage to my server - location S:\scans
I have a Gestetner DSm721d printer/scanner/copier. How do I program the destination to have the scanner send the image to? It is linked up to my server, I want it to go to a file on my S drive, S:\scans Thanks, Jack
  • 313 Answers
The address can be found if you go to the server an right click the folder it should have full address and this has to be set up then on copier by going into the user toolsd and then administrator you are looking for the address boook if you set up new user an put the adddress as a folder here it should save it you can also do this on the web monitor by typing in the ip address ie http/..ip of machine..192.168. etc
Posted on Jun 15, 2009
X544dn scanning and Windows Server 203
Scanning documents at the printer
1 Load the document into the scanner.
Note: Documents may be loaded into the scanner in multiple ways. For information on the different methods of loading documents into the scanner, see the User's Guide that came with the printer.
2 Touch Scan to Network. If prompted, enter the user name and password used to access the printer. Contact your system support person for login information.
3 Select the destination where you want to receive the scanned document. If prompted, enter the user name and password required to access the destination. Contact your system support person for login information.
4 Some additional job options may be available depending on how the application has been configured. Follow the instructions on the screen to update the options. Contact your system support person for more information on each option.
5 Touch Scan It. Depending on how the application has been configured, you may have the option to preview and make adjustments to scanned pages.
6 To scan additional documents, load the next document into the scanner and select one of the following from the confirmation screen:
• Touch Yes, to same destination to scan the document to the previous destination.
• Touch Yes, to a different destination to scan the document to a different destination.
• Touch No to finish the operation and return to the printer Home screen.
Jul 23, 2012 | Lexmark X544dn All-In-One Laser Printer
No scan options
Did you install the full software before connecting the all-in-one to the computer? If the printer not scanning to the local computer or a networked computer? Were you trying to use the scanner buttons?
If this is a local problem (USB connection) uninstall any generic driver (these only drive the printer) and then unplug the data cable. Next download and install the software from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=439491& (select your OS from the list). Connect data cable when prompted to do so. Try a new data cable if the problems persist (scanners require bidirectional communication and will fail when the printer works).
Try a direct connection (no USB hub or print server).
If the computer failed to respond to scanner button press, make sure that the monitoring program is running. You also need to set up the scan destinations in the HP Solution Center for the buttons to work.
If the scanner program isn't running, you can launch them manually. Computer > Local Disc (C:) > Program Files > HP > Digital Imaging > Bin (double click on each of the above drives/folders). Find either Hpiscnapp.exe or Hpqscnvw.exe and double click to launch the HP scan program.
XP, Vista and Win7 can acquire scans without the HP software but the scanner buttons will not work. All three can acquire scans with Paint (File > Import from Scanner or Camera > New Scan). Vista and Win7 also have Windows Fax and Scan (New Scan).
Since you need to set the destinations, you should use the HP software to launch scans first. This lets you get a feel for the defaults that will be best to put into the destinations.
I hope this helps.
(If the unit is networked, I do not know how the software connects.)
Sep 09, 2010 | HP Photosmart 3310 Printer
Problem with scanner not maintaining profile and producing network error, usually re initiallizing the scanner from the location works, but not always
Go into the copier's web page and look at your scan destinations. If they are IP addresses then they will change everytime DHCP assigns new IP addresses to your clients. If your clients don't reboot their machines then the old IP address information will still be in the copier. If the destination is a computer name you either need to get a local DNS server involved or update the DNS ip's in your web page.
Mar 24, 2010 | Sharp AR-BC320 All-In-One Led Printer
Gestetner 2712 as a scanner
Yes they can.
Hope i helped you.
Thanks for using "Fixya".
Jun 23, 2009 | Gestetner 2712 Digital Imaging System...
Scanner Delivery server fails on my Gestetner dsc232
First, it doesn't work on Vista, if you have upgraded you OS??
So, have all of the destinations disappeared off the display?, and "updating destination list has failed' message displays" (or something similar).
If this is the case........ have you tried going into the "Scanrouter V2 admin utility", and under the "server" button select "set I/O device", then select "remove". If you are asked to "retain settings" select "no". Then click "add", then "Browse", it should find the machine, select "ok" then name it whatever you want -it's for identification only
This helps when (for some reason) the machine has become disasscociated with the Ip address for lack of a better description -particularily if the software is not installed on a machine with a statc IP.
OTHERWISE
Do the destinations still appear but the scans do not reach their destination even though they appear to be sent?
This happens when the Windows login password has been changed, because Scanrouter is linked to the admin password.
The way to tell is if you click to open the "Scanrouter V2 admin Utility", and get a message pertaining to a "wrong password" or similar. - Enter the NEW windows login password
OR
Has windows Firewall been enabled? TCP port #3670 needs to be opened
Please let me know if any of these solutions help, and Please rate me :)
Mar 19, 2009 | Gestetner DSc232sp Copier
Ricoh MP4000B
hi
a rijas working in dubai
my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
Feb 18, 2009 | Office Equipment & Supplies
Gestetner DSC224 Scanning and Fax Issues
scanrouter? disable delivery server from scanner menu
Jan 22, 2009 | Gestetner DSc224 Copier
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Konica Minolta Bizhub Copier/Printer How to Scan
When specifying the destination you need to complete the address to include the folder. Just like specifying a path manually, the server/folder.
You need add the folder as part of the server path.
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
136 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
