Question about Windsor VS14 Versamatic Bagged Upright Vacuum
Windsor versamatic red button reset how to
The red button makes a noise when trying to push it in , also there is a stange noise comming from the roller .  I know this should be simple , but how do you reset this feature?
  • Anonymous Jan 14, 2008
    I have replaced the roller and it stopped making the noise for a short time.
  • adseverance May 11, 2010
    What model do you have, the Versamatic plus or the
    regular versamatic?
3 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: on a versamatic windsor how full can the bag get
About 2 inches from the bottom of the bag.
Posted on Feb 22, 2009
  • 4088 Answers
SOURCE: My Windsor Versamatic plus has all of the sudden
Likely the wheels are frozen with thread and hair at the sides of the wheels. Check for free movement of each wheel and pick out the debris around any that are hard to turn. Long needles and tweezers are good tools for this.
Posted on Jul 26, 2009
How do you replace the motor pulley on a windsor versamatic vs14 vaccum
I own a few Windsors and I believe those pulleys are threaded on in reverse. Unfortunately there's nothing to grab hold of on the other end while turning the pulley with a pair of pliers. When servicing Hako machines I normally remove the armature from the motor and grab it with a towel while turning the pulley off. Give that a try, if no luck I'll get into one of my Windors and see how its configured.
Nov 27, 2017 | Windsor Vacuums
The handle release on windsor s12 won't spring into place
You likely have one of two problems. Your return spring is broken, or your axle is bent. If your axle is bent, carefully inspect your chassis to be sure that the bent axle has not cracked or otherwise damaged the chassis. I have included a parts list as well as some links to these parts for your reference. http://windsorvacuums.com/partslists/s12_PARTS.pdf 2010 Axle Spring 86146570 windsor allstar javelin 5053 Windsor Sensor Axle 86137990 allstar javelin
Jun 17, 2014 | Windsor VS14 Versamatic Bagged Upright...
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
My windsor sensor 12 inch vacuum is to hard to push. I bought a new one and its doing the same thing. My vacuum repair man says he cant fix the problem. My shoulders are sore from working so hard. Help
It\'s possibly the type of carpet you\'re using it on. The sensors use the brush speed and the amount of air flow to determine carpet height. Some berber, and tweeds make these things horrible to push. We sell sebo, who make the windsor and we\'ve had the same issue on random carpeting. We end up selling the G- Series units in these situations because they adjust manually so not to suck themselves tight to the floor. Sebo/Windsor make amazing products but there\'s just no helping this, it happens sometimes.
Happy Vacuuming!
The Vac Dr.
The Vac Dr is always happy to help. If you\'re having trouble finding someone to help contact us here.
Jul 20, 2012 | Windsor SR12 Sensor Bagged Upright Vacuum
Broken motor pulley windsor vacuum
I have the same problem, maybe we can flip the belt over and let it run on the smooth side for a while. That's what the person before me did and it lasted a good 6 months.
Feb 24, 2012 | Windsor VS14 Versamatic Bagged Upright...
The red button at the side of the roller brush to reset it on my dc24 rollerball doesn't seem to do anthing. What am I doing wrong the diagram shows that you push the button forward but I can hardly get my...
you need to use something small to push the red pin right in, make sure there is nothing blocked in the roller and this should reset the motor. The roller needs to be switched on next to the power button is well.
Oct 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My power head on my Kenmore canister sweeper dont work right.How do I get it apart and fix the problem?
Try pushing the reset button on the top of the power head first. There is a protection system on Kenmore canisters that protect the belt from breaking, and if something was vacuumed up into the head, it will cause this reset switch to activate to protect the belt. On the top of the power head look for the a small red button, or a grey button that says overload protection switch, and push down on it.
If the power nozzle lights are coming on, and the machine is making noise, then this means that the belt may be off inside the head, however if you're not getting any power, and the head light is not coming on, then this is probably a bad hose on the unit.
I have written a detailed repair on how to replace the belt on the Kenmore canisters on Fixya, just follow the link below. The only difference on the one I helped repair and yours may be the that the screws are actually located on the bottom of the power nozzle rather then underneath of the headlight cover. The other steps will be the same, just unscrew the screws on the bottom of the power head.
Here's the link:
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
Please let me know if this didn't fix it, and I'll help you walk through this further and help you diagnosis the power head further.
Thanks,
Chris J.
GoVacuum.com
Apr 13, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
My Windsor Versamatic plus has all of the sudden become very hard to push. I maintain this vaccum very well. It picks up fine, just to heavy tp push apparently
Jul 26, 2009 | Vacuums
Windsor VS14 Versamatic Bagged Upright Vacuum Logo
342 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
