Suddenly SNOW on all channels
2 yrs ago had intermittant transmission (?) problems on channels 39-50 only. Put on new coax cable - same problem.: otherwise all worked OK. 2 nights ago fell asleep with TV on - woke up to SNOW on all channels. Re-connected coax with no difference. TV is about 20-25 yrs old - is a Sears Series LXI 25" color TV with remote. Have Comcast Cable - no box was required.
  • 1,889 Answers
Your tuner has failed;
time for another set the cost to repair is too high
Posted on May 29, 2009
  • 34 Answers
A lot of comcast systems are switching to all digital to free up bandwith. if thats the case in your area then you will need a digital transport adapter or a digital box
Posted on Oct 19, 2009
Grandson played with remote now only getting snow on tv. on correct channel and input setting. tried turning on and off.
If your set is connected via the RF coax cable from a cable box, what may have happened is that you may still be selecting the RF input, but not cable channels.....you may now be linked the the old analog channels that were for over the air broadcasts. There is a menu option that selects the type of tuner that is used for the coax input.
Mar 15, 2015 | Televison & Video
Hello.... and H-E-L-P please ! 11 month old Samsung ua60f8000 connected via coax to antenna, suddenly "no signal".... have reset, retuned (now no channels) and tried all except a new coax (waiting for
It is possible that the cable to your antenna is broken somewhere. You have the right idea to start there.
It is also possible that your TV is looking at CABLE instead of AIR, or visa versa.
Nov 15, 2014 | Televison & Video
How to connect my Sharp Aquos TV to my Dgtec HD box
It will depend on what output connections the box has. Some examples:
If coax to box and coax to set: in menu make sure set to Cable or Catv and put set on channel designed for this box (usually channel 3) and turn set and box on---with this connection set stays on a channel and box provides and changes channels.
If box has audio/video outs connect to one like it on the set , a input and put set to that input--turn box on and change channels.
Box and set of course both will be turned on.
Jun 13, 2012 | Televison & Video
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
RCA XL100 20" Snow on screen
you have lost one of 3 things,Antenna/Cable, Tuner or part of your tv's power supply
Sep 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Snow on screen and no picture on my DS35510
Hi and welcome to FixYa,
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Good luck and Thank you for using FixYa.
Jan 04, 2009 | Sanyo DS35510 35" TV
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Female coax connector in tv bad?
Did the cable person take a reading on the signal level at the cable outlet on the wall and did the cable person check the TV setting to make sure they are correct. TV could be set on the wrong channel also.
Nov 08, 2007 | Televison & Video
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Electro Med Services...
