Question about OEM Systems Car Audio & Video
Want park brake override code for dvd in dash to play
New 09 GMC Yukon Denali has enterteiment system with back up camera. Is there an override code for dvd (has park brake warning)
  • 30 Answers
SOURCE: bypass parking brake
All you need to do is take the parking brake wire from the radio and put it directly to a ground source. I have the same radio.
Posted on Feb 21, 2008
heejoke
  • 4 Answers
SOURCE: dual Parking Brake Code HELP!!
the esiest way to solve these problem is to make a switch connecting the blue/white with the brown cable it would work just find i had the same problem.
Posted on Mar 13, 2008
Does the suggestion by djBass work with the avx800 too?
Posted on Jun 16, 2008
  • 566 Answers
SOURCE: 03 Yukon denali park brake warning wont turn off
hi for info the brakes warning light on dash is also an indication that brake fluid level is low? or there may be a leak resulting in fluid level drop ? also considering age of car you may need to inspect brake pads wear ? if your car has low brake pads wear indicators attached to pads ? or the hand brake switch req's checking to ensure it is being pushed to off position when h/brak is down ? so fluid level low is the obviouse 1st check as fluid will displace from reservoir as pads wear low hence the level indicator on fill cap trips on may i suggest if it is low level b4 you top up? check your b/pads if you have not done so recently? or replaced since new ? hope this helps you locate problem best wishes from the uk
Posted on Jan 03, 2009
  • 102 Answers
SOURCE: Need color codes for radio in 2002 gmc yukon denali
2002 GMC Yukon Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Posted on May 24, 2009
Why does my gmc denali loose radio reception or signal when i start my motor
when you turn your key from on to start it uses the power that would normaly play the radio to help activate the selinoid
Aug 24, 2013 | Yukon 2008-2009 Gmc Yukon Denali Nav/dvd...
1999 Yukon Denali stop shifting out of park.
Check the brake lights when this happens, if they are not on then you have found the problem it is the brake light circuit. Go under the dash if the brick lights don't work and check the brake light switch above the brake pedal, it should have 12 volts in and out with the brake pedal pushed down. See typical brake light switch location below. #4 in diagram is brk lite switch.
Oct 11, 2012 | 1999 GMC Yukon Denali
Gmc yukon has the abs & parking brake light
you have to fix the problem with ur brakes- first check the wiring ,connectors and connection clips to the abs sensors and modulator if looks ok than have truck scanned some auto stores such as auto zone / advanced auto do it for free the code will give u a start point towards fixing ur problem--visual inspection of brakes doesnt always show problem
Nov 26, 2009 | 2001 GMC Yukon Denali
2007 GMC YUKON denali, rear brakes have an air
Here's a link to a thorough article on the subject which should help you...
http://www.aa1car.com/library/abs_bleeding.htm
Oct 13, 2009 | 2007 GMC Yukon XL Denali
Can't get rear parking brake off 04 Yukon Denali XL
You are going to have to pry it over the axle on one side of the park brake shoe assembly with either a pry bar or screwdriver. then just pop the new one back over the axle in the same way. Hope this helps
Aug 05, 2009 | 2006 GMC Yukon Denali
GMC Yukon XL Denali 2004 gauges don't work
GM has an issue with dash clusters since 2002 and the company will not admit to it. We pay $250 each time to swap out the clusters. Let me know what city you are in and I will find you a company locally that replaces clusters.
Jul 25, 2009 | 2006 GMC Yukon Denali
May 23, 2009 | 2002 GMC Yukon Denali
Jan 02, 2009 | 2003 GMC Yukon Denali
Car Audio & Video Logo
428 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
