Is there a setting to print in B/W only?
Is there a setting so I can do black and white printing only.....a couple of color cartridges are out of ink and I don't need to print anything in color at this time anyway
  • j_nistor May 29, 2009
    thanks a bunch
  • 13,433 Answers
Yes
When printing press file,then print, from there select printing preferences go over the pages and look for black and white setting or grayscale setting.
it will print in black and white only.
Posted on May 29, 2009
  • 489 Answers
For many printers, you can click on the Preferences button in the Print dialog to bring up another property sheet. Select the Color tab, choose the option to Print in grayscale and set the drop-down list to Black ink only. This works for almost every color HP printer I have ever seen and it should be available for most other color printers as well.
  • 489 Answers
There are always settings to change in printer settings under printers folder of windows
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Can't print photo in black and white
Could this be the problem? From the User Guide: "Print Color images in Black and White -- Print your color images in black and white to save the ink in your color ink cartridge.
NOTE: You cannot select this setting if you have selected Color Cartridge for all Black Printing"
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Lexmark X2600 printer will not print in black and white
you may check your only black ink cartridge
longer time less using cause ink chanel(holes) dryer, could not print out even refilled.you may take out the ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X2600 InkJet Printer
Won't print with just black ink cartridge
A part solution is print/properties/maintenance/ink cartridge settings/select black only.
You do initially have to buy another color cartridge but you won'thave to buy another expensive color cartridge again in the future.
I
Nov 13, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
Printing in black & white when color cartridge ran out
I had the same problem. Had no choice but to buy the colors I ran out to make the printer work. In order to avoid future problems and save on color inked I attempted to follow the steps of a previous posting, however, that did not work for me. This is what I had did. Print, select properties, advance, continue, check box - Black ink only. Remember when you decide to print in color you must reset your setting and take out the check from the - Black ink only.
Sep 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
587 people viewed this question
jasbo
jasbo
