Question about Motorola Lands Phones
Automted system does not recognize diall
I have a motorrola d210 tripple handset. Problem is when you ring business numbers that have automated system., telling you to press 1,2,3,etc to put you through to the correct department the automated system does not pik up the dial so for instance you press 1 when requested it does not pik the dial when pressed. I have tried this with numerous automated systems but same problem. Can i please get some help. Thanks
Dean
Try using a "real' telephone. It might just be that the phone system does not recognize the sound emitted by the phone sending it the signals.
I have found this to be the case sometimes with apartment dwellers who need to release the front door when a visitor comes to gain entry to the lobby.
If you read the literature, Motorola might address the issue--keep in mind that they want to sell phones and appear in the best light possible--this of course would preclude any mention of things such as this. Good luck. TJ
Posted on May 29, 2009
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
Motorola d210
Try it with and then without area code. If the user is in an area code the same as a metro area but lives outside the metro area the area code may be required by your service provider (Sprint, Verizon)...Where AT&T doesn't require the area code.. This is a problem on Buisness Phone systems in setting system to dial as Long Distance or Local call.
Aug 18, 2014 | Cell Phones
Phone displaying 'Out of Range', no dialling tone
This could be due to the fact that one of your phones is off the hook or unplugged. Check and make sure that all devices are operational and charged.. Don't forget to check the phone line itseft.
Cheers
Jan 21, 2014 | Uniden 5.8GHz Expandable Cordless Phone...
Panasonic tda200 we have 2 extention 1 is 888- 2 is 889 if both number are busy co call is transfer the 883 ? i dont want to Transfer
you can cancel the call forwarding from both phones by dialling *7100(lift handset first) from each phone
Aug 08, 2010 | Panasonic (KX-TDA200)
All calls go directly to voice mail
The phone is probably forwarded to voicemail. Leave the handset down and dial "Feature # 4". This will remove the call forwarding option. There are also automated call forwarding options -- Call Forward-No Answer, and Call Forward-Busy. CF/NA will transfer calls to voicemail after 4-rings (for instance). CF/B sends all calls to voicemail if you are on your phone. System programming, by a certified technician, is required to make changes to these options. Hope this helps.
Jul 15, 2010 | NorStar Meridian M7310 Phone
No ringing tone on handset
Need a manual for Williams sonoma bread machine
Model # 2094
Ray
Sep 15, 2009 | Panasonic Cell Phones
Where is the redial button on my KX-A144ES
you need to press the interlocking circles button on the handset (in the centre at the top) to show the last number dialled (incidentally, you can now press the down arrow to scroll through previous dialled numbers).
When you get to the one you want, simply press the green handset button to dial the number displayed.
That's last number re-dial in 2 steps (there is no single click solution)
Feb 06, 2009 | BellSouth GH5816 Cordless Phone
M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Nov 05, 2008 | NorStar Meridian M7310 Phone
Philips dect 521/525 - 3 year old phone - No dialling tone on one handset
I had the same problem and my hubby managed to reset the phone by simply unplugging it from the electical network. Just wait for few minutes (the date goes back to 1 Jan 2005), then plug it again and try to dial a number. It should work.
Oct 05, 2008 | Philips DECT 2151 Cordless Phone
Lands Phones Logo
94 people viewed this question
Top Motorola Lands Phones Experts
David Payne
David Payne
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
