Question about Cell Phones
Can't get rid of silent mode
My phone is on silent so does not ring. How can i change this i have been to settings and set the ring tone to high and still it does not ring.
  • karensavage2 May 30, 2009
    Thank you for your suggestion. I tried the controls on the side of the phone and have been to the settings to try and change the ringtone but to no avail. The phone is a nokia 6021.
  • 77 Answers
Depending on what type and make of phone; you might have volume control on the sides of the phone. If so try to adjust the ring type there.
Another thing to try would be to check the profile setting of your phone. Some Motorola phones have this option in which a paticular ringtone is assigned to the profile. Change the profile setting on your screen and this should solve your issue.
Posted on May 29, 2009
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
Intercom green and red light flashing with no tone
go to setting open tone setting option check weather volume level is high or low and check your current profile is in silent mode or in genearl mode, if it is in silent mode means change it in to general mode.
Dec 26, 2010 | Cell Phones
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
How can i set message ring tone.
Go to menu>my stuff> tools >utilities. Scroll down > my voice.
Then press record .
To set it as your ringtone:
Go to menu, settings, then profiles. Then it takes you to flight mode, silent, vibrate, ring, and etc. On the side it says options. Select it. Scroll down to customize. Then just change the ringtone or scroll down to message tone.
Jul 25, 2009 | Pantech Matrix Cell Phone
How to deactivate silent mode of SGH-E250 model
Press and hold the # button until it tells you its on normal mode. If this still doesnt work go into settings, profile settings, then i think it will be general and change the ring/message tone as it must be on off..if that makes sense. hope i helped.
Jun 04, 2009 | O2 Samsung SGH-E250 Cellular Phone
Samsung sgh - u600 mobile keypad tone wont change
samsun 3500 do not have a keypad tone and when i try putting volume it tells me exit silent mode i am not in silent mode and my phone does not ring either
Oct 21, 2008 | Samsung SGH-U600
NO RINGING TONE
hi!
check your mobile is in silent mode!
After that goto tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume!
or
Otherwise goto profile personalise setting tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume
Good luck
Jul 18, 2008 | RIM BlackBerry Pearl Smartphone
Motorola Razor -Silent Mode
what you have to do is customize it as silent mode by turn the ringing volume down and turning the sounds off. this can be done in profiles.
please rate me. thank you.
May 26, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
448 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
