Question about Kenmore Washing Machines
Trys to spin but stops every time.
I have a Kenmore Elite Calypso wash motion, model #21066 that does not spin. It was working fine then suddenly stopped working. It stopped spinning amidst a wash and the timer stops counting time as well. It trys to spin then stops and it I move it, it trys to start spinning again. I moved it around then it allowed me to wash 3 times but stopped at the forth again. This time, it released water which spilled on the floor between one of these washes. It makes a buzzying sound then stops over and over again. I have tried to re-arrange the clothes and even removed it all to make sure it was not a balancing issue. Someone PLEASE illuminate me! Thanks!
  • gpcnmona Jun 08, 2009
    iT DOES NOT SPIN NOR AGITATE. :(
  • Samuel Charles Spriggs May 11, 2010
    Does it agitate okay and not spin or does not do either?
    Sergeant:
  • 209 Answers
Sounds like you have a small clothing garment maybe a sock or similar stuck in the waste pump.
Take the lid off, Follow the bottom rubber hose inwards it connects to the waste pump, remove the hose from the pump and check inside the hose and the pump for clothing, make sure the pump spindle can spin round with your finger. Please make sure the power is switched off before removing the lid
Posted on May 29, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
Model # 110.22064101 Kenmore calypso elite washer makes a whirring sound when washing and the washer tub doesn't always stop correctly when the cycle is complete. It will move around instead of being...
The motor coupling is about to completly go out on you and then it will not spin at all. This is common on these machines. the repair should be under $100.00. The motor brake may also be dragging.
Nov 10, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite top load calypso wash motion at the end of wash cycle it does not spin and flashes a LD on display I have to turn off and just do a spin cycle to to spin dry.
LD (long drain). possible blockage at pump..check to see if pump spline is stripped. also if the drain hose is plumbed in airtight then this may be slowing the draining process.
Jun 13, 2009 | Kenmore Washing Machines
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Jan 20, 2008 | Kenmore Elite 21086
Washing Machines Logo
186 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
