Question about Magic Chef CGS3760 Gas Kitchen Range
Magic chef stove
I have the digital pad to set my oven temp ect the pad does not light up so I don't know what my oven temp is Is the a fuse or something I can check?
  • ckg6 Mar 02, 2009
    Same problem - digital oven display goes on and off so I can't tell what temperature the oven is set at. Anyone able to fix it? The recall notice didn't help me.
  • Magic Chef Master
  • 4,655 Answers
Sorry to inform you that your oven is on a recall list,here is the link click the link and it may save you a lot!
 https://repair.maytag.com/repair/cooktop.jsp?siteCd=MT_EN_CA
Posted on Oct 24, 2007
I oven is showing -F7- what is that
You have a function key stuck or shorted. Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Regards, --W/D-- Please feel free to rate this solution! Thanx!
Jul 31, 2009 | Magic Chef Ovens
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
1992 magic chef (panasonic) microwave. Model M15E-5B. In a RV with very little use. Ran empty. 5 seconds blue flash at top of oven. Panel lights but only time pads work. Seconds, minutes, ect. Fix with new...
Try this site, it has the best advice on almost ANY microwave problem you can have, I know I read something almost identical to your prob. here:
http://www.repairfaq.org/sam/micfaq.htm.
Mar 31, 2009 | Magic Chef CMV1000B Microwave Oven
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
MAGIC CHEF GAS STOVE/OVEN TURNS ON & OFF
your technical support is horrible after being left on hold for so long and being told to pay 10.00 just to ask a question is poor business.
Nov 19, 2008 | Cooktops
Magic chef stove
If the oven is working but the control does not light up then you will have to replace the control.  If the oven doesn't work then will have to check and see if you have power to the control.  If power is there then the control is bad.
Oct 25, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef CGS3760 Gas Kitchen Range Logo
245 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
