Question about Sony STR-V444ES Receiver
Popping sound at random times out of my AV Reciever/Surround sound system when video is playing.
Random popping sound out of speakers when video is playing .
  • 87 Answers
Clean and tighten all connections. Get a can of spray tuner and contact cleaner from Radio Shack to clean the volume and tone controls if you have access to the body of those controls. Some disassembly required. If this doesn't help, suspect a bad variable resistor in the amplifier circuit.
Posted on May 29, 2009
Two of my speakers are not working -no sound
If they are the rear surround speakers, they will not produce sound at all times, check this with a surround sound movie that will engage the speakers. Check the settings on the reciever to be sure you are in the correct surround sound mode, and check the movie menu to be sure you are playing in correct format. Also check that wires are correctly installed, observing polarity, under terminals at both the speakers and at the reciever. I hope this is useful, but not being onsite these are just a few troubleshooting tips to narrow the problem.
Feb 07, 2013 | Audio Players & Recorders
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
Problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Jul 25, 2009 | Yamaha HTR-6030 Receiver
Surround Sound system ''popping'' through speakers
if you have left the stereo on for long periods of time heat builds up in the electronic circuts and it starts buzzing and popping through the speakers. What I would do is turn it off and let it cool down for a couple hours and it should be fine for a whole or just buy a new surround system.
Apr 22, 2009 | Audio Players & Recorders
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
How to connect dvd player to AV reciever
S-Video is a media type that only carries video. Unfortunately the LG unit was designed only to be a self contained surround sound unit. There are only video outputs to the television on this unit. Because of the unit having surround sound capabilities, LG felt that their wasn't a need for audio output. You would need to buy a new DVD player to allow audio from the DVD to your new Yamaha unit. Good Luck!
Jan 22, 2009 | Audio Players & Recorders
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
Cant install surround system to TV/DVD/XBOX360
Use audio out on t/v and plug that into input on the surround reciever
Dec 22, 2008 | Durabrand HT-3915 System
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony STR-V444ES Receiver Logo
755 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
