Question about Krups FBC112 1600 Watts Toaster Oven with Convection Cooking
Failure to operate
I used the toaster for lunch, but not a single coil would light for dinner.  The
timer did operate for a while, but eventually failed.  I called the service number, and the woman I talked to said it was an electrical problem. She said we should ship it. But I should contact this site first.
  • GAJon Dec 29, 2007
    All the elements just stopped working. The timer and the other electronics are on and functioning.
  • showtyme000 Feb 22, 2009
    My oven started over heating when using the toaster option. The digital read out became garbled and smoke was coming from the coils. I had to unplug to turn it off. This has happend on a few occaisions.
I had the same problem, and replaced the thermal fuse, (that suspiciously went out shortly after the warranty expired). Since then, it's been going strong for the last couple months. The fuse itself is $2-$5 but will require time, tools and patience. Here are some links:
Posted on Jan 12, 2008
Missing timer knob 1pc?
Oh Kay,
Just go online with "Oster toaster knob"... and cyber-space will come to you...
Oster has their own parts... $$ look reasonable... until you get to the shipping...
You might want to order a bunch ($35) of coffee filters... fly swatters... sheet corner garters + gizmos and oddities all at once for "free shipping" from AMAZON (below)...
Just remember...No such thing as a FREE LUNCH.
Live Well... Be well... & keep that fork out of the toaster!
Jan 24, 2016 | Oster Toaster Ovens
My toaster oven has no power
This can be due to three reasons:
1. It can be fault in the wire to the oven, if the plug is faulty or the wire has opened out.
2. Secondly if the switch to activate the heating coil is bad it will not connect the power to the coil
3. Finally if the coil is OPEN , then it can be checked using a multimeter as also the wire connection to the heating coil.
Aug 25, 2011 | Black & Decker CTO649 Toaster Oven with...
The toaster (upper) part of our 4-slice toaster oven model 6067 suddenly stopped working after several months of using it consistently. Will return it to Target but hoping it's an easy fix. We kind of like...
Hi there. I just repaired mine. The wire connected to left side (as you are looking at the front of the toaster) of the front top heating coil had come off. I replaced all four of the crimps going to each side of each of the top two heating coils as well as the wire going between the front and back coils on the left side. Make sure that you use HIGH TEMP crimps and HIGH TEMP wire. I had the crimps and purchased the wire from a ma and pa repair shop here in my town1_24_2012_10_47_09_pm.jpg
Jan 01, 2011 | Sunbeam 6067 Toaster Oven with Convection...
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
My black and decker toaster oven is less than a year old and it has a burned out smell coming from it. I feel it might be a fire hazard and I am not comfortable using it anymore for fear of fire. What can...
Your problem is very likely the timer switch. They are very poorly made and they have a high failure rate. B&D should have a recall on these switches. It's likely a DKJ/1-60 timer switch. They make a very poor electrical contact which causes the switch and possibly the wall plug to overheat. Mine melted the wire insulation at the switch and failed. These switches are impossible to find fortunately because they are all subject to the same failure. There are a couple timer switches made for Delonghi ovens that will work in the B&D and other ovens that use the DKJ/1-60 timer switch. One is part # 5218104600 which works the same as the B&D switch but it only has about a 13 minute toast timer. Turn it counterCW to turn the oven on. There is another switch with a 120 minute timer which is part # 5218101800 but may be harder to find. The 13 min timer switch can be purchased for $10.98 at Gourmet Depot website. Another solution is to replace the bad switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually but at least you will be able to use the oven and the switches are under $10 and much safer than timer switches.
Mar 06, 2010 | Black & Decker CTO649 Toaster Oven with...
Can I heat tv dinners in my new toaster oven
If the TV Dinner will fit flat on the rack and still allow the door to close, yes, you can heat up a TV Dinner in your toaster oven.
Oct 11, 2009 | Kenmore Toaster Ovens
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
Krups 296 Toaster Oven will not heat
Fusible link inside the unit is probably broken.
Nov 24, 2008 | Krups 296 ProChef Ultra 1500 Watts Toaster...
Toaster oven just stopped working...
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Jul 22, 2007 | Cuisinart TOB-30 Toaster Oven with...
Krups FBC112 1600 Watts Toaster Oven with Convection Cooking Logo
376 people viewed this question
Top Krups Toaster Ovens Experts
Tom Chichester
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
