Question about Kenmore Washing Machines
Washer will not fill or spin, makes a loud noise
My washing mach. will not fill with water or spin
  • 15,935 Answers
The timer is likely failed if both these are happening simultaneously.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Machine Starts filling then spins 3 turns and a loud noise and stops?
Hey friend, I appreciate your post!
From my understanding you Frigidaire washer will fill with water, spin three times, make a loud noise, and then stop. You could possibly be seeing an issue with your control panel or motor. I would recommend having a technician come out to the home to properly diagnose and repair your washer. I hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Washer does not agitate or spin. makes loud noise when it's on:filling, trying to agitate or spin and emptying.
Possible that the INLET valve is also making noise due to faulty coil, check , confirm by disconnecting the valve.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 24, 2013 | Washing Machines
Washer made a loud noise after it filled up
The washer machine tried to spin but the bearings (or other mechanical part) broke. This is a serious issue that needs a technician for repairs.
Sep 07, 2009 | Whirlpool Washing Machines
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Humming noise
if you're talking about during fill probably just a noisy valve may or may not be a real concern just a noise if objectionable replace valve
Sep 01, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore washing maching 25862
yes you need to replace the motor coupling between the motor and transmission let me know how you make out
Dec 21, 2006 | Kenmore 25862 Top Load Washer
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
