Question about Dell OptiPlex 160L (160LMIN) PC Desktop
No signal to monitor / Beeping
Have a Dell Optiplex 160L, would not deliver signal to monitor, checked connections, now it is beeping at me. Sugestions??
  • meteshadow May 11, 2010
    what kind of beeping you have ? how much times ?
Listen to the pattern of beeps, or look at the back of the computer to see the pattern of the diagnostic lights ( 4 lights just under the keyboard/mouse connectors) and check out this site to see what they mean:
Beep Code Meanings
Diagnostic Light Meanings
Posted on May 29, 2009
Can i take the wifi from my dell optiplex 160l and put it in my acer computer?
The answer to your question will depend on what expansion slots your new Acer desktop computer has and whether one of these will match the specific 'half mini PCI-e' card which is used in the Dell Optiplex 160L per http://www.dell.com/uk/business/p/optiplex-160/pd which states it is an Optional Dell Wireless 1397 802.11BG Half Mini-PCIe card.
You will also need to obtain the device drivers for this wireless card in order to use it in the Acer.
Given that the Dell wireless card is only an 11/54MB standard card (802.11BG) I would recommend buying a newer 802.11N wireless card which will be sold with the necessary device driver and software applications needed, will give higher speed connectivity access and be much simpler to install and manage.
Dec 22, 2011 | Dell OptiPlex 160 Desktop Computer (Intel...
Where is the wifi card located optiplex 160 l?
See http://support.euro.dell.com/support/edocs/systems/op160l/en/ug/smtabout.htm#1189371 which is the Dell Optiplex 160L User Guide and shows the internal layout of this computer with instructions for removing expansion cards.
Dec 22, 2011 | Dell OptiPlex 160L (160LMIN) PC Desktop
Dell optiplex hardware failure no screen when I turn it on. What do i do to get the screen to come on. thanks.
Hello,1st Is your computer turning on? Fans spinning? any beeps?
2nd Please check to see all the connections are properly connect (VGA,DVI,Power)3nd - Is you monitor on the right input? VGA,DVIIf you can confirm all the above is correctly plugged and set then you have 2 things that could of failed.1st - your video card. The vidoe card outputs the video signal to the monitor. One reason you make not be getting video feed
2nd - your monitor. try swapping cables or monitor and see if you get any picture.
Is your PC still under warranty? Dell will replace the video card if under warranty.
Nov 17, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Turn on pc then beeps and nothing on monitor
Have your VGA card check by a hardware specialist and possibly the RAM. good luck
Jun 25, 2009 | Dell OptiPlex GX260 PC Desktop
Turn on, starts beeping, nothing else
If a computer starts beeping on start up a critical input or output piece of hardware is missing or improperly installed. Check all cables and connections, start removing
hardware untie you find the problem mysleuth.
Mar 16, 2009 | Dell OptiPlex GX150 SFF (GX150BLACK) PC...
My Dell Optiplex GX1 will not boot. The Monitor shows no signal.
check whether ur ram is working or not. remove the cpu side door and remove the ram from the ram slot and clean it using a eraser gently and fix again it back and power ur pc on and check it
Feb 23, 2009 | Dell OptiPlex GX1 PC Desktop
Ethernet controller
Here is the download page, you need to select model and OS: Driver & Download
Jan 12, 2009 | Dell OptiPlex 160L (160LMIN) PC Desktop
Dell Optiplex 160L Motherboard
Hi there is one more thing you should check before buying another mobo. Trace the wires from your on/off switch on the case, unplug it and then bridge the 2 pins out with a screw driver, this will start the computer. runit as normal, then shut down and see if you get a restart. If the computer does not restart on its own you have a faulty switch. Clean it or replace it. Regards mistyman
Sep 22, 2007 | Computers & Internet
Computers & Internet Logo
560 people viewed this question
Alun Cox
