Question about Zonet ZSR0104CP (zsr0104cp) Router
Can't see both computers in my network places with zonet router
I have two computers both windows xp and a printer connected to a zonet router (zsr0104cp). I am able to access the internet from both computers.
I cannot get the computers two see each other over the network. I want to be able to share files and folders between both computers. I have tried "network setup wizard", I have tried modifying the firewall configurations, I have tried as many things as I can think of and nothing works. I have both computers named the same in work-group name. Any help would be appreciated.
Ron
  • John Moore May 11, 2010
    Have you shared any folders or files or drives? I think if nothing is shared, there is nothing to show. Pick one folder and right click on it. In the dropdown, select "Sharing and Security". On next window, on the Sharing tab, in the second box down "Network Sharing and Security", click the box "Share this folder". If the Folder name is short enough, it will appear in the name box, otherwise, you can name it in less than 12 characters. Select OK button and Windows XP will share that folder for your network. Do this to both computers. The folders do not have to be the same name. Let me know if this helps.
  • 77 Answers
Be certain that you turn off your windows firewall(control panel,systems,firewall).
I would prefer to connect both computers to a switch or hub. Some routers are kind of strange when it comes to sharing files and folders.
Posted on May 29, 2009
    Guru:
  • 523 Answers
U can give the sharing to one of the folders in the PC1 and search the file in the PC2 so that u can transfer the files with the help of network connections
or
The other method is the u can use the PC mover software and transfer the files from one system to other.You can download the s/w from the below link
http://www.freedownloadscenter.com/Utilities/Automation_Utilities/PCmover_Download.html
Regards,
Ayyasam
How do I disable Zonet router's firewall?
You may want to try to manually configure the router with an static DNS. You should be able to contact your ISP for the DNS server IP and then log into your router and enable manual DNS settings on your router to use the DNS IP address.
Since Zonet no longer exist you should have a user guide handy,
http://mypdfmanuals.com/dref/3342684
Dec 06, 2012 | Zonet ZSR4134WE Wireless Router
I cannot get the printer Canon MX870 connected to the computer network. I am running windows XP I have it connected to the home router but when I put in printer name while adding the printer on the...
You cannot just add network printer on Windows XP without the printer software. You can only install it on Windows 7 with no software.
You need to get the canon MX870 software and run it on the computer you want to print files from. 'Before you do it, make you have already setup the printer to connect to your router and also make sure that it is connected to your router before you run the software.
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx870#DriversAndSoftware
Select Windows XP (NOT WINDOWS XP 64) then download and install the first file "mp68-win-mx870-1_04-ea24.exe" Run it and it will show you options. Choose setup wireless there you go! Make sure you are connected to the-same router the printer is connected to.
Please rate 4 stars if this solved your problem. Thanks
Apr 26, 2011 | Office Equipment & Supplies
I Installed the software for the Zonet ZEW2508 on my laptop with windows xp home.. Now what? (I have an operating wireless router already)
Ignore the software and use the built-in wireless utility that comes with Windows to configure your network. There should be a small icon by the clock that looks like a radio antenna with waves, right-click it and select to 'View Available Wireless Networks'. The rest is self-explanatory.
If the Windows utility states that it is not managing your wireless networks, you'll need to disable the Zonet utility first. If you need help with that, let me know.
Good Luck!
-Kevin
Jan 04, 2011 | Zonet ZEW2508 54Mbps WirelessG Usb Adapter
With Zonet ZSR0104CP can't see internet
If the router is connected to the internet then you just have to setup a new internet connection from Network Connections. Select the option for new internet connection. From there read carefully all the options before selecting. And even if you go wrong anywhere, you can come BACK and correct yourself. Select the Router and then give the ID and Password and you will be through.
Nov 02, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
I just set up my computer in a new place. my
ok..
the error that you are getting is related to the hardwired connectivity between the router and the computer,make sure there is a correct cable connected from the back of your computer to the router,and to reset the router what you need to do is if look at the back of the router you will see a button that says reset hold down the button for 60 sec now lights should blink on the router,turn off the router for a min and then power it back the router will be reset to default and make sure the physical setup is done correctly between the router adn the computer..
any problem or confustion even after doing the above steps..plz revert back with the queries...
vedhick
Feb 20, 2009 | Zonet (ZSR0104UP) Router
Can't connect my Linksys WRT54GS router to zonet zps1000
The gateway would be the address that your router uses.
You would plug the print server into the back of the computer using the ethernet line.
Use this link to get into the support section of the website:
http://www.zonetusa.com/index.asp
Dec 30, 2008 | Zonet (ZPS1000) Print Server
Cant find ipp address on computer after cleaned hard drive
Try going to a command prompt and typing ipconfig. If you are connected to a network this will allow you to see your IP address. Assuming of course you are using a flavor of windows.
Dec 19, 2008 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
Trying to set up a network printer with DELL TRUEMIBILE 2350...please help
using windows xp on all the computers, when you connect to the printer windows should automatically install drivers.
1. Goto My Computer, Click My Network Places (Explorer Bar).
2. Click View Workgroup Computers (Explorer Bar)
3. Find the computer that has the printer physically connected to it, open it
4. Find the printer and right click it!
5 Select Connect... and wait for the drivers to install.
this should install the print drivers and install the printer on your computer. the printer should now be available in print dialogs i.e. word etc etc and from the Control Panel > Printers window.
Nov 03, 2007 | Dell Wireless 2350 Router
Zonet ZSR0104CP (zsr0104cp) Router Logo
186 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
