Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover Windtunnel Hello! I had to change the flat belt on my vaccum and now the belt won't stay on. I can replace it, use the vaccum, then the next time the belt comes off. Is there something I did not do right? Thanks for your help! Jennfer
  • Jennifer Keith Creeks Oct 24, 2007
    That is not the problem.  I made sure that the words face the right direction. Infact, it says "this side out".  I read somewhere that it has a safety shut off so that the motor doesn't overheat. So I thought maybe my filters were dirty. So I cleaned them but have yet had a chance to try and actually vacuum.
    I will update!
Your belt may be twisted inside-out. Be sure the printed marks on the belt face away from the pulleys and shaft. The printing should face you.
Posted on Oct 24, 2007
Hoover windtunnel
Hello--How about the Flat belt? That would be my next step...then, if it's still not turning, perhaps the beater/agitator bar's bearings are the culprit...calling for a new beater bar /agitator.
Hope this helps--
Aug 28, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Im having trouble getting thewide flat belt in place on my windtunnel
We have recorded a very helpful do it yourself video on this exact problem. The belt change on a Hoover Windtunnel Self-Propelled is common repair that we see probably more frequently then any other repair. This is badly designed belt system by Hoover, and the way it's designed most people have to replace the belts at least on a yearly basis. The video below will show you exactly how to replace the belt, as well as how to maintain the roller brush to prolong the life of the belt as much as possible.
Here's the video:
I hope that this was helpful to you. If you have any questions about the repair, please feel free to use the Clarification request here on Fixya, and I'll be more then happy to help you further. If you found this helpful, please be sure to rate the repair solution as helpful by clicking the thumbs up icons in the top right hand corner.
Thanks again,
Chris J.
Jan 09, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The belt needs replacing
Here is the manual to your Hoover U6630
it goes into detail on how to change the belt and which belt to purchase. Ask for a flat belt Hoover part No. 38528035 when you're going to purchase the replacement belt
Aug 31, 2009 | Hoover U6630-900 WindTunnel Bagless...
The belt on my hoover will not stay on. It falls
Okay. I would suggest that you have a problem with your roller brush. If the roller becomes clogged with hair/debris, the bearings will sieze, and sometimes even melt the plastic. the roller then has a difficult time turning and will break the belt. If the belt is slipping off, I would suggest that you either have a worn belt, the wrong belt, Or, your "windtunnel" (the half cylindrical insert the roller sets in) is missing. this insert has a "belt guide" that keeps your belt aligned. hope this helps!!!
Jul 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover windtunnel
Put the V belt on the pulley first, then the flat belt, put it over the motor shaft or pulley, then you have to stretch it to go over the pulley next to the V belt pulley.
Jan 18, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
96 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
