Question about Sony SNCRZ25N Network Camera
Sony SNC RZ 25N does not accept power any longer
The Sony SNC RZ 25N camera does not accept power from the 120V AC adapter that has worked and still works. The camera appears sealed thoroughly so a casual repair may not be possible. Any suggestions? It is not on warranty and I understand the Sony Repair facility is in PA and the camera is in Sedona AZ.
Thank you for considering the question.
  • Paul Blessing May 11, 2010
    Do you mean the camera won't power-up? How do you know the transformer is good?
sonyspares
  • 89 Answers
SOURCE: Power button stuck in down position
You may have to change to switch portion and if you need assistance in blow up diagrom or spares, contact me.May take 3 to 4 weeks to get from Sony service.
Posted on Mar 29, 2007
JoeO700
  • 80 Answers
SOURCE: Vertical Black line on display
Rakesh, You have a "dual scan" panel, this is why the line only decends down the screen half-way. This could be a connection problem on the buffer board which causes loss of the drive signal only to that part of the display which it is connected to. The vertical address buffer will be located on the top rear of the display, use great caution in inspecting these cables and connectors. If the integrity of the cable and connector is good the panel itself may be bad due to the drive IC being located on the ribbon cable attached to the panel body. this is better known as COF or, chip-on-film technology. I hope this helps you. Good luck. Joe Weibel CustomElectronics.Org
Posted on Apr 24, 2007
SOURCE: Power button stuck down for good
I have this same problem. I've had the camera for 3 years, and never had a problem until yesterday. The power button stuck down. leaving the camera on. Since I couldn't get it fixed, I decided I'd take out the batteries until I wanted to use it again. I put the batteries in 20 minutes later, and it wouldn't come back on.
I work for a photographer, so I took it in to have him see if he could fix it. He could not. He took the camera apart and said the shutter button and the power button are both connected to the same computer board. He saw no way to fix it besides sending to Sony. I haven't gotten an estimate yet, but my warranty and extended warranty have expired...I'm bitter about it!! They shouldn't have made that type of power button, and from now on I'll know to look for that.
If anyone gets a fix, let me know!!
Posted on Apr 19, 2008
SOURCE: SOny Network Camera SNC-P1
yuirtyrtyrtyrtyrtyrty
Posted on Aug 09, 2008
mistersony
  • 320 Answers
SOURCE: Sony DCR-TRV30 Error Code 31:23
First, you have to disassemble the camcorder to get to the mechanism. Then once you get the mechanism separated from the rest of the unit, the cassette basket or tape loading mech has to be removed. Once you remove that, there is a dress panel with the tape sense LED attached that will have to be reomoved. Behind the dress panel is a swing gear that drives the reels. The swing gear depends on friction from a clutch behind the gear (but it's part of the gear). the reason it stops working is that the clutch wears out so the gear won't swing and engage the reels (Sony calls it a "gooseneck gear" p/n X-3950-364-1) Replace the gooseneck gear and that SHOULD take care of your problem. Also check to make sure the reelshaven't been bent, this sometimes happens if you "misload" a tape. Be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
I have 2 sony snc-rz30N cameras that recently can not be seen on the network. They are all pluged in however the network light on the camera does not come on.
Check the 12 Volt AC adapters for correct levels. Connect one computer ONLY to the cameras on the Ethernet and see if you can communicate. Verify you get composite video from the BNC jack. Check your router.
Jan 25, 2011 | Sony SNC-RZ30N Network Camera
Hi ! i cant find a driver for my model webcam
Driver is available on website other then Sony Support so download it at your own risk. Make sure Anti-Virus software is installed and updated in your computer.
Click HERE to download driver for Sony SNC-P1 camera.
Oct 22, 2009 | Sony SNC-P1 Network Camera
Sony SNC-RZ30N lost connection and preset positions
Have you check switch, in my case the switch has some problems!
Oct 21, 2009 | Sony SNC-RZ30N Network Camera
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Missing preset positions o SNC-RZ30P IP Camera
in the rear camera have the reset, turn off the camera and turn on the camera and holding the reset button.
sony tech: lgzoe2@gmail.com
Jul 08, 2009 | Sony SNC-RZ30N Network Camera
Cant connect to SNCRZ25N via browser.
SNC-RZ25N Sony Network MPEG4 Pan-Tilt-Zoom Color Security Camera ... the SNC-RZ25 is the perfect MPEG-4 PTZ network camera for your remote ..... Sony Security - IP SNCRZ25N network ptz camera with 340 degrees pan, ... 1 2 3 next ... they do not reflect our opinions and we have no responsibility for their content.
Mar 27, 2009 | Sony SNCRZ25N Network Camera Snc RZ25N
Sony SNCRZ25N Network Camera Logo
Top Sony Home Security Experts
JonSnell Electronic
JonSnell Electronic
Are you a Sony Home Security Expert? Answer questions, earn points and help others
