Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
Vizio P50HDM died today, screen went black, no sound and power indicator light remained green. Turned it off and indicator light flashed amber/green. Unplugged from power for several minutes then reconnected power, cooling fans started, heard several clicks from within case, and then nothing. Green indicator light remained on. Suggestions? Vizio P50HDM died today, screen went black, no sound and power indicator light remained green. Turned it off and indicator light flashed amber/green. Unplugged from power for several minutes then reconnected power, cooling fans started, heard several clicks from within case, and then nothing. Green indicator light remained on. Suggestions? Already replaced fuses.
  • 92 Answers
This is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
Posted on Jun 16, 2009
  • kevin davis
    kevin davis Jun 14, 2014
    same with my plasma today. black screen, no power, won't power up
SOURCE: Vizio 50" P50hdm Audio with No Video
when tv is on horz trans is damge
Posted on Jul 11, 2008
jdbouncer
  • 72 Answers
SOURCE: p50hdm
Ok first i need to know is the TV showing anything at all or just a blank screen ? And if you know what the Y or Z board is who is the manufactured of the plasma panel is ?
Posted on Dec 06, 2008
dsacco86
  • 1077 Answers
SOURCE: I can find where to conect my antena cable on a Vizio p50hdm
Your TV is a monitor only. That means it does not have a tuner inside for an antenna. You may try a VCR for a tuner and hook up the antenna to that. Good Luck
Posted on Jan 25, 2009
  • 4 Answers
SOURCE: vizio p50hdm i get sound but no picture, wahat part do i order?
prob just a simple scart lead problem
Posted on Mar 02, 2010
SOURCE: Vizio model no.P50HDM, loud pop then no picture. Green pwr ind on
P50HDM, loud pop then no pic...
Posted on Apr 17, 2010
Vizio P50HDM Plasma
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 23, 2014 | Vizio 50" p50hdm high definition...
My vizio p50hdm tv has a solid green light indicating it is turned on but I have no picture or volume. What needs to be replaced? Thx
The Lifetime warranty is a fantsy as most of you help, You should check with the company before posting untrue statements. Nothing has a lifetime warranty so dont waste your time with flights of fancy.
May 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
My vizio p50hdm made a popping sound from the rear. Afterwards, the picture disappeared and tv screen was black (as if the power was off). Then within a minute the picture reappeared but looked real dull...
The z-sustain board is bad. One of the the heat sinks on the board is cool to the touch. These had LG circuit boards and the number on the sticker, on the board, was a good LG part number. The part numbers were 6871QZH044A.
Do a search on the internet with Google, Yahoo, or Ebay with this part number. The board unplugs and the new one plugs back up. Not an advanced technical repair. Unplug the set and take the back off and match the picture on Ebay with the one in your set. And especially match the part numer.
May 24, 2011 | V, Inc. Vizio P50HD Plasma Television
Vizio plasma. screen went black, and the power light went out.
Sounds like the power suply went. I don't know that model off the top of my head, but you might find a replacement here http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=EU&Category_Code=PLA
-=/ Daft Tech /=-
Oct 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Oct 17, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
2,030 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
