Question about Karcher 2500 PSI Pressure Washer
Poor pressure karcher g 2500 pressure washer with a 5.5 honda engine. No high pressure, hose pulsates as does water out of the outlet. have removed the unloader valve twice and cleaned it to no avail
    Habit-Forming:
  • 174 Answers
I had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
Posted on May 31, 2009
Devilbis Excell pressure washer with Honda engine runs smoothly without wand, but stalls when wand is attached.
If the pressure unloader is not working correctly and/or the nozzle is partially clogged with debris, the engine will be overtasked. Try lowering the pressure by turning the pressure knob to lowest setting and test. If the engine continues to run, gradually increase the pressure. Try using the washer set to about 75% of rated capacity and use max pressure for stubborn stains. Using any machine at max will shorten the life of components. If lowering pressure does not help, then unloader is faulty or stuck. Try storing the unit with oil in the pump. Remove both hoses and infuse oil into water inlet intill all the water is displaced (let set for day or two). Good luck
Sep 27, 2011 | Karcher 2500 PSI Pressure Washer
KARCHER 2400 PSI HONDA ENG GC SERIES 160 RESIDENTIAL PREMIUM
Hello there.
If the washer is loosing pressure then it needs to be looked at under warranty, im not sure where the fault would be, but another expert may well know.
If you don't get any suggestions then i would take it back and ask for a replacement or repair.
Hope this helps.
May 09, 2008 | Karcher 2500 PSI Pressure Washer
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
No pressure coming out of hose when motor is going hard I can put my finger on the end of the spray wond and there is hardly anything Karcher 5.0hp GC160 K2400HH
First thing is remove the water supply house and check the water screen for clogs. Remove the hose washer and pull the screen out. Wash and clean the screen then re-install. Make sure your using a 5/8" hose as a supply hose and that the water faucett is turned all the way on.
If after all of the above it still has low pressure the unloader valve is most likely corroded or has debris in the seals.
Download this parts manual The unloader / thermal valve that is supposed to reset is Item(s) 9 {Valve 60 GND} and 12 {Spill Valve} of detail A on page 11. The spring, seals and housing need a good thorough cleaning to get high pressure. If the seals are damaged they will have to be replaced. Lubricate the seals with lubriplate white grease No. 105 before you reassemble the unloader valve. Grease link: http://www.lubriplate.com/webstore/default.aspx This grease is at any automotive store.
Thanks for using FixYa.
Kelly
May 10, 2010 | Karcher 2500 PSI Pressure Washer
I have a K3.91M karcher waterblaster that has had little use and it pulsates at idle what is the solution?
A couple of other options spring to mind. It may be an air-lock, try disconnecting the high pressure hose and letting the water flow under its own pressure for 5 mins or so. It may also be a crack in the cyliner head...£16 from Espares..takes about an hour to strip and refit. you will need allen keys (to remove the cylinder head) and torx type screwdrivers for the casing.
Feb 22, 2010 | Karcher PSI Electric Pressure Washer
Pressure washer has no pressure
hi i am a pressure washer engineer, dont just jump in and get an unloader there is a few test you can do first! first of all is the machine sucking from a drum or off mains water pressure, if sucking force feed the pump with water to see if there is any leaks. and post reply on here or ring on 07973527954
Jan 14, 2010 | Karcher 2500 PSI Pressure Washer
When pressure washer engine is running and hooked to water supply, there is no water spray with trigger is depressed
Hi Have you checked that your nozzle in the lance end is not blocked. Please try this and then try without the high pressure hose attached.
Oct 27, 2009 | Karcher 2500 PSI Pressure Washer
I have a Karcher pressure washer that leaks from the pump when operating.
could be little plastic pressure hose outlet,they can be porous and let pin holes of water through,pull plastic casing apart and remove high pressure hose outlet (black 'L' shaped pipe gun pressure hose outlet,ive repaired a couple,and machine works fine after
Oct 18, 2009 | Garden
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Sep 20, 2009 | Karcher Garden
Karcher 2500 PSI Pressure Washer Logo
720 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
