Question about HP Photosmart C7280 Laser Printer
HP C7280 duplex scan problem
Have C7280 with duplex feeder, but canno scan both side of sheet when Solution Centre scan preferences set to 'Scan both sides of the orginal when using duplex feeder'. Any ideas?
    Guru:
  • 224 Answers
IN XP
click on start and select control panel.
in control panel on the top left hand click on switch to classic view if is not there dont worry.
Next Goto printers and faxes and then right click the printer icon and select printing prefrences and in the advanced tab make sure that duplex printing is enabled.
IN vista
Click on start
in the start search box type "printers" and click on ok.
Single left click your printer and then single right click your printer icon and single left click the option that says printing prefrences.
in the advanced tab make sure that duplex printing is enabled.Now try to give the scan command and it will work as long as the paper is fed in from the adf it will be better
Posted on May 30, 2009
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
Jun 19, 2012 | HP J4680 Office Jet All-In-One Printer
Tip
ERROR codes Canon 3525
Canon 3525 E000 Fuser problem E000 Heat E010 Main motor, motor board, clock pulse E010 Drive E030 Counter E030 Counter E050 Duplex side to side problem E050 Duplex problem with cross alignment E051 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E202 Scan home sensor or home scan E204 Scan E204 Document sensor, scan reverse sensor or scale E210 Lens problem E210 Lens E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E400 Document feed problem E500 Sorter E620 Editor E620 Editing problem
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3025
Canon 3025
E000 Fuser problem
E000 Heat
E000 Fuser problem
E010 Drive
E030 Counter
E030 Counter
E200 Scan problem
E204 Scan
E210 Lens problem
E210 Lens
E220 Lens
E240 DC controller
E500 Sorter
E620 Editor
My scanner just started smearing the first page of a duplex to pdf but when I scan just front of document it doesn't smear it
Hi
Your question is not clear.
Sometimes using technical jargon makes it harder for people to understand each other (this applies to both askers and answerers).
I always advise askers to use normal language as much as possible and answerers to do the same and where jargon is unavoidable, to explain as they go along.
Please post again to clarify what you mean by "..a duplex to pdf..", in normal language not in technical jargon.
A PDF is not a real, physical document. It is a digital document on a computer or a webpage created in PDF format.
A Duplex document is a real document, printed on both sides of each sheet of paper.
If you are trying to scan a multiple page Duplex Document using the Sheet Feeder of your scanner, the ink on the reverse side may be getting caught up in, affecting and/or staining one of the rollers in the Sheet Feeder.
The bottom roller in most non-industrial Scanner Sheet Feeders expects to touch only the plain reverse side of a sheet of paper as it is passed through and turned over to rest on the Platten (scanning surface) of the scanner ready to be scanned.
Multifunction printers with built in scanners and sheet feeders and duplex printing capability are designed in a way that makes them more forgiving of dealing with duplex printed paper.
Duplex printing printed in a laser printer is less likely to cause a problem as long as it is allowed to dry thoroughly. Inkjet printing that is allowed to drry thoroughly should also be okay.
If the scanning is being attempted very soon after printing, then the wetness of the printing may be the problem.
Sheet Feeders that handle duplex printed sheets invariably become stained and need periodic cleaning.
If the document is not too long, you may have to scan it manually, page-by-page.
If the document exists as a PDF somewhere on your computer or on the internet, then it is unclear why you would need to scan it. This is why your question is puzzling.
Post a further comment, if this answer does not help you solve the problem.
I hope this helps.
Aug 25, 2011 | Fujitsu fi-5750C Flatbed Scanner
Can i get front and back side of pages scanned at a time, if yes then how? how can i scan a book of 50 pages by giving one command?
What scanning software are you using? In Adobe Acrobat Professional 9, you can set up different scan profiles, including duplex scanning. The sheet feeder holds up to 50 pages; you just tell the software to make all pages one pdf.
Dec 02, 2010 | Kodak i1220 Pass-Through Scanner
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Jul 22, 2009 | HP Photosmart C7280 Laser Printer
C7280 hp printer won't scan, it says "no scan options"
First, make sure the HP Digital Imagin Monitor is running on your computer. Start it if it is not currently running. Open HP Soluction Center and select your printer (if there are multiple printers listed) and click on Settings. Click Scan Settings and Preferences. Click Scan To... Setup. Click on Destination List. Make sure that the scan destinations you want are populated in the right-hand list box. If the destination list is already populated, you will need to uninstall and reinstall the software.
Jul 10, 2009 | HP Photosmart C7280 Printer
Can't scan to computer
Should be in the HP print centre software on your computer
Apr 13, 2009 | HP Photosmart C7280 Printer
No duplex scanning
Try going to the hp solution center
Then settings, scan settings, scan preferences (third from top), under the automatic tab, bottom of list is “Scan both sides of the original when using duplex feeder”
I’m using version 70.0.128.000 of the HP Solution Center if that helps.
I told my brother once to ask HP support about a problem for his laptop, and they proceeded to instruct him how to make the problem worse and royally screw up stuff that was completely unrelated to his problem.
Jan 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP Photosmart C7280 Laser Printer Logo
428 people viewed this question
Seeker5211
Seeker5211
